When JD 14SB was made.
/ When JD 14SB was made. #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I bought a JD 14SB self-propelled 21" walk behind mower on Saturday at an estate sale. It was practically full of fuel and looks very new. Started immediately, and I mowed the whole front yard. Then took the blade off and sharpened it. It hadn't been off in a while and was dull. Changed the oil and put synthetic into it. Seemed to only take 1/2 quart.
Anyone know when these were made? It isn't in the current JD model lineup but appears almost identical to their most expensive walk-behind currently sold, except for lower hp.
Is 800-522-7448 is right number to order a manual for it?
Ralph
/ When JD 14SB was made. #2
I can check when I get home but I believe I bought my 14SB back in '95. I still use it and have never had a problem with it. IMHO they are a very good mower :)
I went back to the estate sale today. The lady in charge said they told her it was a 1998.
It really looks almost new. They had another very scruffy-looking lawn mower and not much lawn. Suspect they mainly used the scruffy one. The air cleaner on the 14sb is spanking clean.
Ralph
/ When JD 14SB was made. #5
Ralph, to answer your question 1-800-522-7448 is the correct number to order JD manuals.
Ken
Mine is silver, natural aluminum casing color.
Does it really only take 1/2 quart of oil?
Ralph
/ When JD 14SB was made. #7
In the OM for 14SB's w/ serial #'s 470001-, it states in the oil change section to fill w/ 20 oz (0.6L) of oil; it says to let the dipstick rest on the tube & not to thread it in while checking the oil level; once oil level is correct then thread the dipstick tube into final position. Check to see if the diptick tube has the engine oil capacity stamped on it, it may say cap. is 20 oz., that's the same cap. you find on Deere's latest walk-behind mowers.
2014 KOMATSU D65PX-17 CRAWLER DOZER (A65056)
2014 KOMATSU...
2015 Case TR320 (A64911)
2015 Case TR320...
Hydraulic Breaker Skid Steer Attachment (A66734)
Hydraulic Breaker...
Cushman Hauler 1200X Gas Golf Cart (A64912)
Cushman Hauler...
2016 John Deere WG48A (A64912)
2016 John Deere...
Shop Cart (A68134)
Shop Cart (A68134)
