When is it best to Disc
   / When is it best to Disc #1
MichiganIron
Silver Member, Advertiser
Central Michigan
Full line of KIOTI Tractors, BEFCO and Worksaver Implements
We just had both of our fields sprayed down. It was about time, they were both over 8 years old, and started to get too heavy with Thistle and Nettle. We had them sprayed down the last week of August and are pretty well burnt off now. We plan to re-seed in the spring. Is it best to let it sit for the winter, or should the fields be disced just before the first frost to get the debris into the soil? All suggestions welcome.
   / When is it best to Disc #2
What type of disc and what type of soil? If this is unbroken sod it will take a heavy disc or an offset disc to work it up unless light sandy soil.
What are you planting in the spring?
UNUSED INDUSTRIAS AMERICA 180 HYD SCRAPE BLADE (A54756)
UNUSED INDUSTRIAS...
1993 FORD F-350XL SINGLE CAB FLATBED TRUCK (A51406)
1993 FORD F-350XL...
40' CONTAINER (A51244)
2016 John Deere Gator 825i 4x4 Utility Cart (A55787)
2016 John Deere...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
Hydraulic Hose Crimper (A50775)
Hydraulic Hose...
