When I start my bush hog ES2352 the bendix gets caught up in the flywheel
   / When I start my bush hog ES2352 the bendix gets caught up in the flywheel #1
Colleenrdoucet
Bush HogES2352
   / When I start my bush hog ES2352 the bendix gets caught up in the flywheel #2
It could be the spring in your Bendix is too weak to disengage it when the engine starts. A new Bendix could cure your problem.
   / When I start my bush hog ES2352 the bendix gets caught up in the flywheel #3
I agree with roadworthy. That would be one that I would remove the starter and investigate first. I wouldn’t try it in operation, be afraid I would do more damage
   / When I start my bush hog ES2352 the bendix gets caught up in the flywheel #4
Does it sound like the starter is still engaged and trying to start the engine?
Most starters the spinning engine spins the bedix gear and forces it back towards the starter once the power to the starter is cut.
   / When I start my bush hog ES2352 the bendix gets caught up in the flywheel #5
Dirt, debris or lack of lubrication can also make the bendix stick in the flywheel.
2015 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2015 MACK GU713...
LINDE H70 FORKLIFT (A50854)
LINDE H70 FORKLIFT...
2013 Honda CR-Z (A50324)
2013 Honda CR-Z...
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2005 Construction Trailer Specialists BDT-40 Bottom Dump T/A 40ft Trailer (A49461)
2005 Construction...
