Front-End Loader When do you need to remove your FEL?
   / When do you need to remove your FEL? #31
I just put one on a L3130 that I have 150 hours on.
http://www.tractorbynet.com/forums/showthread.php?t=106097
I was shocked how it change the tractor, I went from a sports car to a bulldozer, as I said in the thread posted, I'm sure glad I got a removable one!
It's one of those things, what ever you get use to you don't notice, after having the tractor for a year without it I'm glad I can drop it off.:D
   / When do you need to remove your FEL? #32
I understand what you are saying about taking the arms off for mowing and have had a misjudged loader bump when mowing, but the bucket has also saved me while mowing. I have some slopes to mow and there have been times I needed to lower the bucket to the ground to steady the tractor. Now, one could argue that I shouldn't have been mowing any place where that was necessary, but i can't control the terrain, and the grass won't stop growing. The bucket does take alot of bouncing when mowing my 5 acre field, but when on the slopes, probably another 1.5 acre I find my bucket a necessity for balance. Never had it off in 4 years. I use it too much, and not for big things, more of a wheel barrow on steroids. I think each terrain situation causes different strategies.
   / When do you need to remove your FEL? #33
I do the same... lowering the fel while mowing on steep slope.
A quick hitch can save you a lot of trouble. I take my fel off to put on my forklift.
   / When do you need to remove your FEL? #34
I keep my FEL on as I am usually multitasking the tractor. I have ~7A's+ of sloped field that I need to rotary cut- the FEL helps add to stability and balance the rig out while mowing. It is very effective at knocking down the vegetation and finding "new" obstructions as I mow slow with the FEL relatively low to the ground. My field is open so manuverability is not a problem and the NH TC design gives better visibility than some of the other tractor models/brands. Jay
   / When do you need to remove your FEL? #35
I take mine off when mowing (RFM) and plowing and discing mine and my fathers gardens otherwise it is on. After taking it on and off a few times, I can do it quicker and easier than changing the rear attachments, and the advantage of maneuverability and increased visibility is worth the effort.
2009 MULTIQUIP 25KW GENERATOR (A53843)
2009 MULTIQUIP...
Case Compact Wheel Loader Skid Steer (A55851)
Case Compact Wheel...
2018 John Deere TX (A53317)
2018 John Deere TX...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
2000 Ford F-250 Pickup Truck (A55852)
2000 Ford F-250...
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
