When do you fix weepy cylinder ?
   / When do you fix weepy cylinder ? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
The lift cylinder on my Fisher snow plow always has a little fluid dribbling down the out side. Not enough to make blue drips in the snow or require adding fluid during the long plow season. But I keep looking at it and wondering if it is bad enough to warrent repair. The plow is 10 years old. Anyone have any guide lines they use for this kind of thing ? If I fix it it will be my first time working on a cylinder.
   / When do you fix weepy cylinder ? #2
I would only fix it if it was dripping...but you may want to get a seal kit for it to keep in stock just in case.
   / When do you fix weepy cylinder ? #3
I think August is a safe month to install the seal kit, the snowy ones are no fun.
Craig Clayton
   / When do you fix weepy cylinder ? #4
Dumb question but in the cylinder repairable or welded variety. On my low end Western Suburbanite the cylinders are throw away versions.
Roy
   / When do you fix weepy cylinder ? #5
One of the combines was losing over a gallon a day for a good part of last season , Not stopping to do that when the sun is shining !
One of the lift cylinders on the dozer loses about a gallon a day too .
   / When do you fix weepy cylinder ? #6
seals and wipes...
soundguy
Sounds like I can hold off on fixing it - Thanks for the advise. I agree August would be a better time.
Roy
I assume it is repairable but not positive. There is a big nut on top where the ram exits. I guess I just learned what welded cylinder means.
Thanks all
gg
   / When do you fix weepy cylinder ? #8
When it starts to cry.:drool:
   / When do you fix weepy cylinder ? #9
Gordon,
Those plow rams are the easiest to repack DIY.......measure the dia (more than likely 1 1/2" dia) and any plow supply/hyd repair shop has them....
you can tighten up the gland nut for temp fix......not too tight, just a little...
1.500 x 2.000 V packing set......http://www.alleghenyyork.com/pdf/vee/packing_sets.pdf
K-1500 wiper........http://www.alleghenyyork.com/pdf/wipers/k_double.pdf
Easy as pie.........just grease the individual vees lightly as you install them (don't cram them all in at once)......:thumbsup:
Gordon,
Thanks - That does look pretty simple.
I have already tightened the gland nut as much as I dare. Not sure what happens if I go to tight but I assume you can lock the ram ??
2014 Ford F-250 Pickup Truck, VIN # 1FT7W2B66EEA79923 (A48836)
2014 Ford F-250...
2018 FREIGHTLINER CASCADIA SLEEPER (A45679)
2018 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
2013 Dodge Charger Sedan (A48082)
2013 Dodge Charger...
2013 Chevrolet...
