When did mig wire get so expensive?
/ When did mig wire get so expensive? #1
crazyal
Super Member
Northern Vermont
Kubota, Case, Deere
I guess it's been a number of years since I last bought Lincoln wire (.035 SureArc ER70S-6 I think). I think I got either a 33lb or 44lb steel spool for around $40. When I called today the local welding store gave me a price of $165 for a 44lb roll of Lincoln L-56 mig wire. On-line I've seen prices for around $100 with shipping, I like to buy local when possible but unless I can find a better price I'll be ordering it on the internet. I was expecting the price to be around $60, it just caught me off guard when he said $165 over the phone.
/ When did mig wire get so expensive? #2
I tried a few 'other' brands but didn't like their performance so I always end up going back to Lincoln.
/ When did mig wire get so expensive? #4
I previously had a 10 lb roll of lincoln in first one welder , then moved it to another that I purchased . When it ran out , I got the brand listed and have seen no difference in performance or any issue's related to the wire . Now on the other hand , Operator issue's are another story . Son thought My liner was bad , took it out ( it was actually a new one ) and replaced with a 2nd new one I had . Still had issue's . So upon my return , I looked at it to discover when He changed the tip , He installed a .030 tip and was trying to run .035 through it . :laughing:
Unless I try a specific brand from a specific company , My :2cents: is that I never lump anything together .
Fred H.
/ When did mig wire get so expensive? #5
My LWS charged me about $85 for the last 44 lb of Lincoln L56 .035, but that was about a year and a half ago - haven't priced it lately, but that spool is about 80% gone, and now I'm thinkin' I shoulda bought a SPARE :( ...Steve
/ When did mig wire get so expensive? #6
Al, you might ask your LWS if they can match this
WeldingSupply
Scroll down a ways or search the page for L-56, it's about a third of the way down the page - 44 lbs runs around $2 a pound... Steve
/ When did mig wire get so expensive? #7
There are a hundred or more great running wires out there. To ship a 44# spool would easily double the price. Your LWS has several wire options in the store. L56 is fine wire but there are a lot of very good ones for $1 #.. They build BobCat Skid Loaders with Praxair Pro Star wire and it's right in there. Or Airgas Radnor brand is or was National Standard. Or Washington Alloy, Weld-Kote or Pinnacle. All run great.
While I do have a couple projects coming up a 44lb spool will probably last me years. Back when I was doing quite a bit more welding (15 years or so ago) I did experiment with other brands that the local stores carried but didn't really like them. I'm not saying they didn't work well or the welds were inferior, just saying I didn't like it. I don't mind trying a different brand now but I would rather not have a 3 year supply if I don't like it. A friend who owns a welding school is going to get me a price tomorrow. If he can't get a break on the price I've found a couple places listed at slightly under $2/lb and charge around $25 for shipping.
/ When did mig wire get so expensive? #9
Yes, I understand. Go with what you like for sure.. I'm lucky enough to know all of the factory reps in my area and get the stuff for free. I switched to 10# spools for that reason.
I've heard people talk about their wire getting rusty from sitting and other issues. Up here it's not unusual for the garage to get very damp. I've never had a problem and I like the idea of just flicking a switch, opening up the gas bottle, and welding. Also I know the wire speed and voltage needed for a given metal that works well with my mig with Lincoln wire. Maybe I'll experiment on one of my projects with a different brand to see how I like it.
My friend with the welding school says $35 for a 44lb roll. I told him I was looking for Lincoln brand (texted him to double check), if so then I'll just buy it through him and be done with it.
/ When did mig wire get so expensive? #11
I use the smaller 10-12 lb spools in my welder, but have issues with wire rusting if it sets around too long. I solved the problem by getting a 5-gallon sheet-metal tub with a tight fitting metal lid, and store my spools of wire in that. I throw in a couple cubes of camphor, and with the lid closed it keeps all the rust away. Never had a problem since I started doing that, and it's a cheap solution.
Camphor in your toolbox will also keep the rust away there. It's an old-timey solution that still works very well, and isn't very expensive.
/ When did mig wire get so expensive? #12
The L56 wire is decent but, I personally really prefer the Praxair wire. At $1.20/lb it's a really good deal as well if you have one local.
/ When did mig wire get so expensive? #13
I've looked for camphor on a couple of occasions over the years for this reason, but not recently. Never had any luck. Got a source?
/ When did mig wire get so expensive? #14
You might check Amazon... I got a small jar of camphor cubes for a decent price. Some sort of Indian cultural thing, but still just camphor.
Update... Yes, it's on Amazon, and you can buy a little or a lot.... Check here for an assortment of options.
/ When did mig wire get so expensive? #15
Thanks - Seems pretty cheap. How much do you need? Does a small tablet go a long way or do you scatter a few around a drawer?
/ When did mig wire get so expensive? #16
In a sealed can, they'll last a very long time. They slowly sublime and coat the metal surfaces, to prevent rust. A half-inch "tablet" ought to last a few months in a tool chest.
/ When did mig wire get so expensive? #17
Another form of dessicant is sold in RV shops. I think its the same stuff you find packed with a new camera etc. Inexpensive and it might be easier to find.
2006 Hummer H3 4WD SUV (A61569)
2006 Hummer H3 4WD...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
2013 Chevrolet Silverado 2500 Ext Cab Pick-Up Truck (A60352)
2013 Chevrolet...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
2006 CATERPILLAR D6N CRAWLER DOZER (A62129)
2006 CATERPILLAR...
