When did Jinmas get better?
/ When did Jinmas get better? #1
RidgeHiker
Upper California Mountains
Kioti DK5010 with KL5510 Loader & 72" Bucket. Kawasaki Mule Pro MX SE with 66" snow plow.
People have commented in other threads, including the one I started on a Jinma 354, that the Chinese tractors have been getting better.
Regarding the Jinmas, is there a particular year or approximate time that is a turning point in quality, reliability, etc.?
The 354 I am looking at is a 2006.
Thanks folks!
/ When did Jinmas get better? #2
Model years don't mean the same thing to Chinese tractor manufacturers as it does to say American auto manufacturers. In this case it was an evolutionary process, going back to the 1990s. As negative feedback and constructive criticism worked its way from the owners - through the retailers - back to China - little improvements/enhancements showed up regularly. They were sort of on-demand items, rather than model-year changes. The only significant dividing line - to me - would be between the 2006 and 2007 model years. Since 2007, small diesel tractor engines have had to comply with EPA Tier 3 mandates. So on which side of that line you shop - depends upon how you feel about the EPA I guess.
//greg//
//greg//
Do the higher standards translate to more anti-smog devices?
/ When did Jinmas get better? #5
Yup. But the upside is that - from 2007 on - they're also ULSD compatible. On 2006 and earlier, the collective wisdom here advocates treating ULSD either in the container or in the tank. Most common is adding Power Service/Kleen Diesel, but there area plenty of other local equivalents. Over the life of the tractor, the cost of fuel supplements can mount up. Also, ULSD shrinks conventional rubber hoses and seals. Fuel leaks are the eventual result. 2007 and later tractors have treated rubber (Viton I think) that is not supposed to be affected by ULSD
//greg//
/ When did Jinmas get better? #6
Hello All,
Don't mean to hi jack your post, but if my Jinma motor is a 395 and an EPA Motor, am I good with the new fuel?
Thanks,
Rick
/ When did Jinmas get better? #7
Hard to say without knowing the model year. As stated above; 2007 and later, yes. 2006 and older will eventually need new rubber in the fuel delivery system, and treating the ULSD fuel with an appropriate supplement is strongly encouraged.
//greg//
Thanks All for your help!!!
We decided not to go for the Jinma.
/ When did Jinmas get better? #9
Hello All,
My Jinma is a 2005, maybe that is why I had to replace a soft rubber line that runs to the one side of the Valve cover???? What else will need replaced in the future? and what type of material/Tubing/hose should I be using?
Thanks in advance,
Rick
/ When did Jinmas get better? #10
Hello All,
Doubtful Rick, that doesn't carry fuel. Pretty sure that's part of the crankcase breather. The usual reason I've seen them go is because they collapsed after being kinked. It's rubber hoses and seals in the fuel delivery system that shrink from constant contact with ULSD. When than happens, just make sure the stuff you replace it with is approved for use with ULSD. I think the trade name is Viton.
Here's an edited extract from an EPA document:
Question: Are there any special concerns that owner/operators of diesel vehicles and equipment should be aware of in transitioning to ULSD fuel?
Answer: There have been no major obstacles to using ULSD fuel as the primary fuel for existing diesel engines. The fuel has been available in many parts of the U.S. since 2004 and required for onroad use in urban Alaska and the rest of the U.S. since 2006. ULSD fuel has slightly less energy content than other diesel fuels, therefore fuel economy in diesel engines will be reduced slightly. Some owner/operators have found that time between oil changes can be extended for engines using ULSD fuel. The issue with fuel leakage around seals and hoses can be resolved by replacing seals and hoses with Viton seal material. The use of ULSD may also require more frequent changing of fuel filters. The engine manufacturer should be contacted for questions related to specific engines.
Viton is also highly recommended for folks who've switched to biofuel or biofuel blends.
//greg//
/ When did Jinmas get better? #11
Thanks Greg, It sure seemed the rubber hose I replaced carried fuel, as it was leaking/pumping fuel when the engine was running and no leaks when not running
Thanks for the info,,
Rick
/ When did Jinmas get better? #12
might a been the fuel return line hose to the fuel tank, instead of crankcase ventilation hose Ed
/ When did Jinmas get better? #13
Well, the fuel return lines are near the valve cover. But they don't go into it. Steel lines carry pressurized fuel up to the injectors (near the valve cover). But the injectors don't ever use all the fuel delivered. What's not used for one combustion cycle is carried back to the tank on those thin black hoses. The fuel just keeps making a loop. So maybe it was a piece of return hose you're talkin' about. If true, then yes. They may look braided outside, but they're rubber inside.
//greg//
/ When did Jinmas get better? #14
Hello All,
Thanks,
Rick
Better to add an additive to your fuel such as Power Service. The problem with ULSD is the reduced lubrication of the top end of the engine. I guess the newer diesels have hard valves and seats.
Anyway, Power Service additives do lube the top end. A quart bottle goes quite a ways and should last you a season.
Make sure you read the instructions when adding the Power Service (or what ever you use) to the fuel.
2025 Kivel 48in Forks and Frame Tractor Attachment (A61567)
2025 Kivel 48in...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2018 Dodge Charger Sedan (A61569)
2018 Dodge Charger...
STAINLESS STEEL FILTERS (PALLET) (A60736)
STAINLESS STEEL...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
1991 TRAILMASTER CRUDE TRAILER (A60736)
1991 TRAILMASTER...
