When 400 hp isn't enough.
/ When 400 hp isn't enough. #21
I understand the rat spooking the horses, but I'd love to see how the team was rigged to the truck. What part of that chariot was strong enough to hook to a chain with all that pulling going on? The way the chariot jumped around, I'm inclined to think it was floating on top of the rigging. When the horses pulled the rigging tight, it popped the chariot up. I'm also impressed with those horses the way they seemed to dig into the ice with their hooves and all pull together. That was a beautiful sight. I'd bet that milk truck driver couldn't say thank you enough.:thumbsup:
Probably hooked up with chain or tow strap. There would have to be a steel drawbar down the center of the chariot.
Keep in mind those horses weight near a ton each, so they don't need a lot of traction to get the truck moving, just have to shift their weight forward a bit. That's a lot of energy.
/ When 400 hp isn't enough. #22
But-but, how much torque is being applied??:laughing:
Dear Mr Engineer Man,
Precisely, how can a horse apply torque?:drool:
On a more serious note, I regularly, watch draft horses in competition. A 2 horse team can pull over 10,000 lbs on a sled with a roughly 32 sq/ft contact patch. That's a lot of friction to overcome. A rolling load should be a piece of cake, ice or not.:thumbsup:
/ When 400 hp isn't enough. #23
It looked to me is all the truck needed was a little help. I'm always amazed/frustrated on how much snow i can wade and not get stuck. Than the next time I'm stuck on a turd.
/ When 400 hp isn't enough. #24
I have to admit that this was good...
And the mouse was down right funny...
Wonder what the horses stepped on to scare it out of the snow bank?
/ When 400 hp isn't enough. #25
No doubt, but it's all in how you hook up to the ground.
And they DO "hook up to the ground" (-:
My bet is that their shoes pretty much bite into ice.
I know they throw up great clods of dirt when pulling stone boats.
Anyone see why they do the little side hop somewhere around 18 seconds in ?
SO scared of the mouse that ran across the road.
I didn't see it, someone told me about it - then it took a couple more views to catch it.
/ When 400 hp isn't enough. #26
That was a pretty good video.
Only way it could have been better was if it was a Budweiser truck. Could have been a new commercial.!:thumbsup:
/ When 400 hp isn't enough. #27
If only you were an Ad rep-- you could sell that one!!!
J
/ When 400 hp isn't enough. #29
Now lets see a 4hp motor do that. :laughing::laughing:
Yeah...:confused2:
A 4HP engine could do that fine. Yould just need traction or a solid pull point. A bit more complicated than horses with ice shoes tho - esp since each can output well over 10HP momentarily. A motor driven by an engine would better a apply the grunt followed seamlessly by faster pull like a locomotive.
larry
/ When 400 hp isn't enough. #31
What interests me about this:
Compare the amount of reduced friction the horses have in the snow versus the amount of reduced friction the truck also has. On bare ground, the horses would have more friction to apply their pulling force, but the truck would also create more friction.
Would the team be able to move the weight of the truck more easily on bare ground or not?
To those of you who will say the truck wouldn't be stuck at all if the ground was bare....I already thought of that.
/ When 400 hp isn't enough. #32
Horses essentially walk on spikes. In pulling, most weight is on the rears. For those horses its 4000# per sq foot .. and even more concentrated by the shoe. Probably around 40,000# per sq ft till the shoe fully penetrates. That tends to dig in ... like chains ... and that doesnt count cleats that may be used on shoes in ice country.
larry
/ When 400 hp isn't enough. #33
Ice cork shoes are why old tractors had corked ring chains that tear paved roads to pieces. Horses have the ability to give a jerk too that is tough to do in a tractor without going over board and tearing the chain in two.
The problem with the horses is they can't keep up that same pull all day like a tractor. Of course a tractor can't build another small tractor inside of it.
/ When 400 hp isn't enough. #34
I like Ole Red. The one on the left. He's my kinda horse. That rat didn't spook him one bit because he has seen a lot of those in his day. Now those other three are a different story. They are kind of goofy and nervous. They may be colts in training and Mr. Farmer has Ole Red teamed with them for a reason. And if you watch closely Ole Red is smart too. He let those colts do most of the pulling.:laughing:
/ When 400 hp isn't enough. #35
larry
I agree, they have BITE, even though their hooves are bigger than my dinner plate (-:
I had a thought about the weight of a horse being leaned forwards on it's legs and in my mind I was comparing that to how LITTLE force a 200 lb person exerts against a gutter when on a ladder at a similar angle.
I found the thread on when trees were BIG at just about that time, which confirmed that horses can too pull with great FORCE, though perhaps not FAST and for only a limited distance before needing rest.
I am going to have to draw this out, but at an intuitive level it doesn't seem that horses should be able to pull very hard JUST by leaning forwards, even with their legs at 45 degrees to the ground (& they never are).
Just extending strong muscles should make them go UP as well as forwards, so some of the power goes into lifting them vertically.
It doesn't seem reasonable that a 1 ton mass (animal or object) could do that.
Is it their high center of gravity that gets levered down close to the ground ?
Hmmm, but the hitch is up at about belly height...
/ When 400 hp isn't enough. #36
]/QUOTE]
They sorta hunker down and then straighten up when starting a real heavy load. Takes a little to get a team properly trained for real pulling.:thumbsup:
/ When 400 hp isn't enough. #37
He's my favorite, too. What a monster. He's nearly 2 hands taller than the others. The dapple next to him nearly came unglued when that rat ran across.:laughing:
/ When 400 hp isn't enough. #38
When a horse throws his weight into the hitch collar full tilt, and the hitch is a good one, from their chest down to near the ground some several feet behind them, there are only a few things going on, I wish I could draw on this thing.
-The front legs are out of the equation almost, they are just balancing, little to no weight on them.
-The rear legs are extending with the opposing forces being the horses weight down and the collar backwards.
I drew a little picture but it is terrible. The horse isn't leaning a little like your ladder, they just pick up their front feet so their ladder jumps from a slight lean to a barely 30 degrees above the ground lean. Its would be like putting your ladder only 3 fee up on the wall then trying to walk along it.
/ When 400 hp isn't enough. #39
Yeah, I think I got it (-:
Unlike the guy on the ladder - that is still almost upright - the horse could just about curl his front legs up and scratch his chest.
It is his weight 4 or 5 ft ahead of his hind hooves that is coming down.
You could figure it from where his c of g is, 60% of their weight is on the front when they stand - that head weighs more than most men and it hangs way out forwards.
On a different scale; we did that at camp - tug 'o war - almost laying flat to pull the other guys into the mud (-:
It is kinda/sorta/almost like the final stage of an over center latch.
I've seen 'em pull stone boats - YES, it is impressive.
I've also seen a Suffolk Punch being tacked up for it's new owner's first driving lesson.
Nobody seemed to know that he had "Pulled" in a previous life, he was "just so huge and cuddly and looked like he needed a carriage, coz he's too wide to ride" (paraphrased).
It quickly became apparent when he heard something hook up right behind him.
They don't actually WAIT for the verbal command (-:
This is your NEW career fella, just STAND until told to walk on.
/ When 400 hp isn't enough. #40
You got it. The front quarters of a horse is heavy and way forward. Just picking up the fronts and locking the rears exerts a lot of force. And a horse really pulling for all its worth will lower itself reducing backtip torque so they can use the full capability of their muscles. This was a trademark pull conformation of Justin Morgan, the originating Morgan Sire, who was able to pull much more in proportion to his weight than other horses.
Breeds of Livestock - Morgan Horse
larry
(2) 380/85R28 TIRES W/ (10) LUG WHEELS (A64280)
(2) 380/85R28...
2005 International 4400 S/A Day Cab Truck Tractor (A61573)
2005 International...
2019 CATERPILLAR CUV82 UTV (A64280)
2019 CATERPILLAR...
2023 Mercury Verado 350HP Outboard Boat Motor (A61574)
2023 Mercury...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2012 FORD F-250 SUPER DUTY SERVICE TRUCK (A64280)
2012 FORD F-250...
