wheels vs skids on blower
/ wheels vs skids on blower #1
emery
Western Mass
Kubota b9200
I have a paved drive and am contemplating replacing the small skids on my 3pt snowblower with heavy duty swivel casters. I would mount them on the 2 channel frame members just behind the auger box.
Has anyone already done this? Anyone see any potential problems?
The benefit would be less wear/tear on blacktop with wheels versus skids. The only problem I forsee is less functionality if I wanted to clear nonpaved areas.
/ wheels vs skids on blower #2
I would think wheels would be better for the pavement,for skids do leave heavy marks when turning and the wheels would turn if keep well lube.
/ wheels vs skids on blower #3
I wonder if something like a plastic lawn mower mowing deck caster wouldn't work out as well - i.e. 4"-5" diameter one-piece jobbies (non-rotating axis) that are on some of the higher end LT decks (lawn striping?). Might allow a more simple/compact mount, and be just as blacktop friendly without rust. But, I guess the big issue here would be wear.
/ wheels vs skids on blower #4
I'd think that the casters or wheels would stop rolling pretty quickly due to them getting clogged up with snow and ice. I think you'd just end up with non-rolling rubber/plastic shoes, which would probably wear down pretty quick on a paved surface.
I run a front blower and a rear blade on a paved surface with no shoes on either; they leave very little markings and don't dig into the pavement at all.
Since you have a 3pt blower, you should be able to raise/tilt it a bit with the top link, an adjustment that I can't do with a front blower. This would pull the edge of the blower off the pavement so that it wouldn't scrape or dig.
2006 International 4200 2,000 Gallon Water Truck (A64553)
2006 International...
2012 Mercury 25HP Outboard Boat Motor. (A66738)
2012 Mercury 25HP...
2019 KENWORTH T880 TRI-DRIVE HYDROVAC TRK (A67714)
2019 KENWORTH T880...
23.1-26 Tires - Set of 2 (A68134)
23.1-26 Tires -...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
SARLO (A64557)
SARLO (A64557)
