wheels vs skids on blower
/ wheels vs skids on blower #1
emery
Western Mass
Kubota b9200
I have a paved drive and am contemplating replacing the small skids on my 3pt snowblower with heavy duty swivel casters. I would mount them on the 2 channel frame members just behind the auger box.
Has anyone already done this? Anyone see any potential problems?
The benefit would be less wear/tear on blacktop with wheels versus skids. The only problem I forsee is less functionality if I wanted to clear nonpaved areas.
/ wheels vs skids on blower #2
I would think wheels would be better for the pavement,for skids do leave heavy marks when turning and the wheels would turn if keep well lube.
/ wheels vs skids on blower #3
I wonder if something like a plastic lawn mower mowing deck caster wouldn't work out as well - i.e. 4"-5" diameter one-piece jobbies (non-rotating axis) that are on some of the higher end LT decks (lawn striping?). Might allow a more simple/compact mount, and be just as blacktop friendly without rust. But, I guess the big issue here would be wear.
/ wheels vs skids on blower #4
I'd think that the casters or wheels would stop rolling pretty quickly due to them getting clogged up with snow and ice. I think you'd just end up with non-rolling rubber/plastic shoes, which would probably wear down pretty quick on a paved surface.
I run a front blower and a rear blade on a paved surface with no shoes on either; they leave very little markings and don't dig into the pavement at all.
Since you have a 3pt blower, you should be able to raise/tilt it a bit with the top link, an adjustment that I can't do with a front blower. This would pull the edge of the blower off the pavement so that it wouldn't scrape or dig.
Generator (A64553)
Generator (A64553)
2014 FREIGHTLINER CASCADIA 113 S/A DAY CAB TRUCK TRACTOR (A69167)
2014 FREIGHTLINER...
2022 HLA 60in. Hydraulic Root Rake Grapple Attachment (A66734)
2022 HLA 60in...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
LANDPRIDE 48" BOX BLADE (A65057)
LANDPRIDE 48" BOX...
PORTA POTTY (A67714)
