Traction Wheels locked ...
   / Wheels locked ... #1
The Tractor Man
Ford 861
Hi Folks ... I have a Ford 861 (Selectomatic Shift) ... I parked the tractor a couple months ago and haven't started it since ... Now it won't start ... I want to put it inside for the winter BUT the wheels do NOT roll freely ... They seem to go in opposite direction when I pull the tractor ... What am I doing wrong ? ... Thanks for any help ... John
   / Wheels locked ... #2
Sounds like it's in gear. Make sure to shift to neutral.
   / Wheels locked ...
Thanks for replying ... I tried neutral and reverse and 1st and second gears ...
   / Wheels locked ... #4
Sounds like even though you "shifted" it into neutral, it didn't go into neutral.
   / Wheels locked ... #5
Apparently there is something wrong with the shifting mechanism it should roll fine in neutral
have you checked to make sure there is plenty of oil in the transmission ?
   / Wheels locked ... #6
It has been 35+ years since I was around a select-o-speed and do not recall if they will shift into neutral without the engine running. Hopefully someone with a better memory will chime in.
   / Wheels locked ... #7
IIRC Ford select-o-speed trans has a release mechanism that enables tractor to be towed without sliding rear tires.
   / Wheels locked ... #8
Exactly. The transmission defaults to park when not running. Right side of the rear axle housing above the running board.
   / Wheels locked ...
THANK YOU all for the replies ... I will check the one above today ... Is it a lever or what ? ...
   / Wheels locked ...
Thanks to everyone here ... I took a long shot and asked a 95 year old man down the road ... Said he had a "Select-O-Speed 861" like mine and still had the manual ... Here is what I found ... see attached ... I feel dumb ... John
   / Wheels locked ... #11
Hope you copied the manual or took photos of every page!
Hope I am around when 95 to share things with neighbors!
   / Wheels locked ... #12
So did you actually get it to work properly ?
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2020 KENWORTH T680...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Hot Pressure Washer Trailer (A59228)
Hot Pressure...
