Wheels for my YM1401D
   / Wheels for my YM1401D #1
sauber
Shortly after purchasing my tractor, I replaced the tires with turf. I would like to put the old tires on wheels so I can play in the snow. Is there a JD conversion? Don't care what color they are as long as they fit the tire and tractor. Any help?
Thanks Dan
   / Wheels for my YM1401D #2
I don't know of any, Sorry.
Might give Lens12 a call or talk to other parts suppliers.
People do like to keep them and often buy additional rims and add turf tires.
If this is any help at all, the following models are the same size as your YM1401 500-12 X 8-16:
YM1300, YM1300D, YM1301, YM1301D, and (maybe) the YM155, YM155D.
Mark
   / Wheels for my YM1401D #4
That's funny. I actually take the R1's off for the winter and put turfs on for snowblower work on my 155D. In my case the driveway is paved and fairly flat and I seem to slide around less with turfs. I suppose if I were to set out in 20" of powder I'd want an ag tread.
   / Wheels for my YM1401D #5
I was wondering the same thing about my larger model, any JD/Yanmar models that would swap?
As I've mentioned a couple times on various forums, the stk wheels/tires on my machine and the tires are slightly over their rating with nothing in the bucket. Also thing I'd like to give a set of R4's a try.
   / Wheels for my YM1401D #6
I have seen Chevy rims used for the rear. The bolt pattern is off , but a rat tail file was all it took to make them fit. If you used a spoke wheel the flat steel center would be easier to file fit than a stock wheel with the taper for the lug nuts.
If you have a few bucks to spare, Hey Wheel will make you any thing you want. I have used him several times to put Industrial tires on these tractors. 785-594-3441
   / Wheels for my YM1401D #7
What part of the world are you, and what size do you need? I plan on selling my 18" wheels next year, but could be talked into getting rid of them now if it works out.
Sorry for the delay...out of town for awhile. I live in Green Bay, WI 54313. Plowed snow the other day with the Ford 1100 and a grader blade. The most fun on a tractor in a long time. LET IT SNOW...
Thanks...Dan
Mag wheels for the Yanmar? I don't know man, the neighbors point at me enough is it is. Are you refering to a standard Chevy steel wheel? I would prefer an OEM or similar wheel.
Thanks...Dan
   / Wheels for my YM1401D #10
The Chevy six bolt pattern is so close a rat tail file will make them fit. The white spoke wheel is flat steel and will work better. The stock Chevy wheel will fit, but the bolt holes are tapered and will be a little harder. Then there is always Hey Wheel.
1263 (A50490)
1263 (A50490)
Cat 305.5E CR Excavator (A52384)
Cat 305.5E CR...
2023 UNVERFERTH 632 LOT IDENTIFIER 147 (A53084)
2023 UNVERFERTH...
UNUSED HURRICANE G350 PORTABLE CEMENT MIXER (A51248)
UNUSED HURRICANE...
2024 Kubota BX23S (Dothan, AL) (A50123)
2024 Kubota BX23S...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
