Wheels dont turn
   / Wheels dont turn #1
Rayreinke
283 massey ferguson
I have a 283 massey. Was shredding all going great. Stopped put tractor in neutral. Left pto running. Got on tractor to go again and it wont move. Good pressure on foot. Feels as if it went into gear. Any ideas
   / Wheels dont turn #2
"Good pressure on foot?" Meaning the clutch? First thought is a clutch issue.
   / Wheels dont turn
Sounds as if the gears are turning inside transmission. Pro does work
   / Wheels dont turn #4
I had a 283 years ago. I'm assuming it's the same tractor. You didn't happen to knock the range lever in neutral? That geared tractor should go. Have you tried all the gears in both ranges?
   / Wheels dont turn #5
If it's not that then the clutch apparently went out.
  • Good Post
Reactions: JWR
   / Wheels dont turn #6
More info
   / Wheels dont turn #7
Does the PTO go through the clutch? So if clutch is depressed it stops?
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
Pump Jack with Battery (A49461)
Pump Jack with...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
(INOP) 2005 JCB 506C TELESCOPIC FORKLIFT (A50459)
(INOP) 2005 JCB...
Landoll (A50657)
Landoll (A50657)
