Ballast Wheel Weights
   / Wheel Weights #1
Anonymous Poster
Epic Contributor
I have two wheel weights (per tire - 4 total) I'm about to mount on a NH TC33D. Will the zinc washers suffice or should I go for the galvanized? How do I get the weights perfectly centered on the rims? Any insight before I do this would be appreciated.
   / Wheel Weights #2
Most tractors won't run but about 20 mph, so centering is primarily for looks anyway. Galvanized washers are better. Use what you have and change them out next year. The important thing is being sure the bolts don't come loose.
   / Wheel Weights #3
JayD, I always use galvanized washers. Like Wen said the centering is mostly for looks, but I saw one once that would shake the tractor that was off center quite a bit. Just get them where they look right and they will be close enought. Make sure they are tight because that is where the most problems will come from. I had a weld break on a wheel weight bracket and it dropped 200 lbs. of weights on the valve stem breaking it. That cost me a $79 service call. So make sure you double check all fasteners and attachment points.
JerryG
   / Wheel Weights
I have a NH 1720 and am interested in rear wheel weights. I don't want to pay for new ones from dealer. Any idease where i amy be able to purchase used?
   / Wheel Weights #6
homer,
Have you check the classifieds also place an ad,maybe visit a couple or farm auctions you be surprise what you may find real cheap.
Thomas..NH /w3tcompact/icons/wink.gif
   / Wheel Weights #7
Haven't tried this yet but on my list of things to do is make some wheel weights out of 45lb olympic size weightlifting plates. I figure some steel plate with the bolts welded for mounting to the inside of the rim and then a steel post in the middle sized for the weight hole. Should be able to get 4 plates per wheel easily at only a 6 inch width which should keep the whole assembly inside the rim. That's only 180 lbs per wheel but if I keep my eyes open I should be able to get the weights cheap. (It would be too expensive to buy them new, I think they go for about $1 per lb.
   / Wheel Weights #8
Gerard -
Using olympic-sized weights is also my backup plan if I never get around to melting the lead that I bought. I even have a friend who works for a fitness equipment manufacturer who says I can come and get all the weights I want for free. Apparently they just toss defective or blemished plates in a pile and have them hauled away periodically.
Best part is, I could have him carry them to my truck. When we used to work out together, he would bench 320 lbs. (compared to my 170). I would say it's because he's 17 years younger than me, but 17 years ago I could barely bench press the blankets off me in the morning. /w3tcompact/icons/crazy.gif
Maybe I should pick some up and drop them in an envelope and mail them to you. /w3tcompact/icons/smile.gif
[Disclaimer to all those who might be getting ideas -- I'm not sure how far I could push his under-the-table offer.]
   / Wheel Weights #9
gerard, I use bar bell weights on my B7100-100 lbs per side and they work fine. You may want to check out some pictures I posted a while back on how I attached them. I made brackets similar to the ones you are considering, but was able to do it without welding (only because I don't know how). I think the post was under attachments or customization....explained how they were made.....the picture of the attachments is included here. Due to wheel size I could only use the 25lb weights. If I remember, cost was only about 45-47 cents per lb. Total cost for 200 lbs of weights and the mounting hardware and bolts was well under $100.
Also, if you can find Mike Simpson's Tractor Page, there are pictures of some pretty heavy duty wheel weight brackets made for a B2400 on that site.
Bob Pence
   / Wheel Weights
Stevepio,
Thanks, looks great. May give it a try.
   / Wheel Weights #11
Bpence,
Looks like a nice setup. Also looks a little simpler than I was talking about which means BETTER! (I've been to Mikes tractor page and he does have a nice setup.) I think I just revised my plans........
Harv,
Feel free to mail me some of those 45 lb plates. What size envelope do you think you'll need?????
PS With all your computer skills can't you find some way to send it as an attachment or have I found the limit of your talent!! /w3tcompact/icons/smile.gif /w3tcompact/icons/smile.gif /w3tcompact/icons/laugh.gif
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A59904)
2003 VOLVO VNL...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A60429)
2024 CATERPILLAR...
