Wheel weights on TC55
   / Wheel weights on TC55 #1
deerhunterf350
St. Louis, Mo
New Holland TC55DA
I am thinking about buying 6 NH rear wheel weights. The Tractor has AG's.
From looking at PineRidge's set up with R4's his rims are dished much deeper than the Ag Rims, and it seems that 3 weights stick out on his unit, and would STICK WAY WAY out of the AG Rim. This could cause a problem with clearance in tight areas. :(
I was wondering if the Inside Diameter of the weight is large enough that one weight could be mounted on the inside of the rim and slide over the Axle Flange, and two weights mounted on the outside of the rim.
From what I remember the whole two times that I have been at the Property since getting the Toy - Tractor, I seems to look like there is plenty of clearance for the weight to not make contact with anything on the inside of the rim.
Could someone post the dimensions ( inside Diameter, OD Diameter, Overall Thickness ) of the NH wheel weights I would appreciate it.
   / Wheel weights on TC55 #2
As per the weights on my TC35
OD= 18"
ID= 9 7/8"
Thick= 5"
The wheel flange on my 35 is larger then the center hole on the weights so no mounting of a weight on the inside of the rim.
Hope this helps
Randy,
Thanks for the Dims.
I was hoping to hear that they may need just a few cast seems cleaned up and they will just barely slide over. Oh well.
Just add 2 to each rim along with the 55 Gal Drum of Concrete, I think 1600#'s should be sufficent ballast.
Dan
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
2014 Doosan DA30 (A51039)
2014 Doosan DA30...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
Seppi Mini BMS 85 Mulcher excavator attachment (A51039)
Seppi Mini BMS 85...
