Ballast wheel weights for L3000DT
   / wheel weights for L3000DT #1
accordionman
wright city, mo.
KUBOTA L3000DT, FEL.
HELLO TO ALL,
well i finished my wheel weights, and they are on the tractor. as you all know
KUBOTA parts are expensive, so i made my own. i used the HACKERS design, and
i bought 12, 25lb. weights from WALMART, at about $10.00 each. i made two plates
1/2in by 12in. diameter, drilled, and machined holes in them, then welded a 1in threaded
rod in the center. painted to match, and mounted on the tractor. then installed 6, 25lbs
on each side. i can tell a difference in the way it handles, and rides, and hopefully it will be
more stable when using the front end loader. i am still working on the grill guard project,
but this one was more important. also working on a canopy.
accordionman
william l. brown
   / wheel weights for L3000DT #2
William,
How about sharing some photos?
Randy
RANDY,
as soon as i get the film processed, i will try to post some pics.
i have never done this before, so i may need help, as well as the
instructions.
accordionman
william l. brown
WHITE CI-7 DRAW WORKS POWERED BY TWIN DETROIT 12.7S (A50854)
WHITE CI-7 DRAW...
2020 KUBOTA RTV...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
