Wheel weights/Ballast box vs Tire filled?
   / Wheel weights/Ballast box vs Tire filled? #11
I don't know what a ballast box even cost...I have seen some homemade ones that will do that job but I agree a box blade is a nice way to go. TSC has a 4ft model thats only $400. If I am working the FEL hard I usually just put the BH on. but for the average/light FEL work, loaded tires and the Box blade work great.
   / Wheel weights/Ballast box vs Tire filled? #12
Charlesaf3 said:
I can imagine George! Any chance anyone was around to watch? I think I would have fallen over laughing myself. Laughing with you of course!
Well, it was everything you might imagine. My first big tractor project. I've got my hoses, antifreeze bottles, filling valve. I've got the tractor rear up on jackstands.
Of course with my wheels configured the way they are the valve is on the inside of the rim. And as fate would have it, I'm under the tractor on my back. I think I was looking to see where the oil drain plugs were for the upcoming 50 hour service. So while I'm down there I figured I'd go ahead and take the valve stem off.
Now I have NO reason to think there is fluid in the tires. I was told there was not. So I just spin the sucker off and then woosh. A literal geyser. Total surprise and confusion. Spitting. Sputtering. Trying desparately to get the thing back on before it empties....which I finally did somehow. I'm sputtering, cussing and trying to get the stuff out of my eyes. I still don't know what kind of fluid is in there.
No one was there to see it, but by this time I'm crawling out from underneath and starting to laugh at myself when my very disinterested teenage neice and daughter ride up on horses. They have the social decency to ask what happened but ride on by before I can explain.
Ever see the Three Stooges plumbing episode? That's all you really need for a mental picture.:D
   / Wheel weights/Ballast box vs Tire filled? #13
funny, that kind of was my mental picture :D
Not that I wouldn't have done the same thing! In the interest of fairness, there was the time I wired a new plug on an extension cord. Wasn't paying attention really, thinking about other things. Went to plug it in and was shocked, literally. I accidentally put a second male end on, and was holding it when I went to test the cord :eek:
The contractor I was talking to at the time said it was one of the happiest moments of his life. :rolleyes:
   / Wheel weights/Ballast box vs Tire filled? #14
It was probably the bio-degradable stuff made from Beats I think....it will burn if you get it in a cut or I bet in your eye but its not suppose to hurt people or animals like calcium Chloride...Important saftey tip....always check air pressure with the valves at the 12 O'clock position.
A friend has a ballast box, he puts pee stone in it, which allows the water to
drain out easily
   / Wheel weights/Ballast box vs Tire filled? #16
My dealer told me the same thing...do not foam fill the tires...would void warranty and be too heavy....not sure about that
   / Wheel weights/Ballast box vs Tire filled? #17
The L4400 manual says not to load the fronts. As usual it does not give a reason.
   / Wheel weights/Ballast box vs Tire filled? #18
I ordered wheel weights with my L-2800 but the rims had no holes to mount them so my dealer had tubes installed in the rear tires and filled them with Calcium Chloride. I agree that no additional weight is needed on the front since I have a FEL. When descending downhill with a loaded bucket I always use 4X4 since my rear tires will break loose and start to slide. I also have a BB or rock rake on the rear all of the time.
   / Wheel weights/Ballast box vs Tire filled? #19
weird - my dealer (neil messick) foamed front and rear tires. I'm very pleased with the results, and will probably have it done on my new tractor.
Case-IH 180 Magnum (A50120)
Case-IH 180 Magnum...
434669 (A48836)
434669 (A48836)
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
Bobcat Skidloader PHD (A50774)
Bobcat Skidloader...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
