Wheel weights/Ballast box vs Tire filled?
   / Wheel weights/Ballast box vs Tire filled? #1
Turtro
New England
When I purchase my tractor the dealer reccomends getting the rear tires filled...is there any advantage to having additional Wheel weights or a ballast box, if the tires are filled?
   / Wheel weights/Ballast box vs Tire filled? #2
yes. THough as usual depends on your usage.
For me, I'm on hills, plus I do a lot of landscaping (blades, etc that touch the ground) and loader work. So that means foam filled tires, front and rear PLUS wheel weights PLUS a heavy implement on the back when I'm doing loader work. I've put a rear wheel in the air despite that with a load of concrete in the bucket. NOT FUN.
No one has ever had too low a center of gravity on a tractor, or too stable a CUT.
   / Wheel weights/Ballast box vs Tire filled? #3
We know nothing of size of tractor you are planning, use, kind of terrain you have, etc... might expand your personal profile to assist in answering your questions.
I'd start with fluid filled rear tires. If you have a FEL, then you WILL want some weight on the rear... boxblade, or manufactured weight. Try an implement on the rear if you have one... some people do prefer a ballast box because it keeps vehicle length down. Don't purchase wheel weights until you have tried all other methods of adding weight and have proven a need for wheel weights.
   / Wheel weights/Ballast box vs Tire filled? #4
Wheel weights hurt like heck when they slip onto your feet. Don't have that problem with filled tires
Ok all thanks for the info... I'll start with filled rear tires, and a ballast box.
   / Wheel weights/Ballast box vs Tire filled? #6
Mechanics have advised me NOT to have foam or fluid weight in front tires, could void warranty....apparently acts differently on differential that just extra weight on ft. bumper. why add weight to the front, resulting in less FELS capacity? bb
   / Wheel weights/Ballast box vs Tire filled? #7
you might rethink the ballast box, unless its really cheap. A box blade pretty much works the same, and has all sorts of other uses.
If I'm not tight, the bush hog also balances well. THough warning, everything becomes tighter with a bush hog on the back!
   / Wheel weights/Ballast box vs Tire filled? #8
A rack of suitcase weights is an option to wheel weights. With some implements like a PHD or subsoiler being used in hardpan, the weight needs to be placed on top of the implement. A 3ph hydro-downpressure unit can be helpful. You can also find old barbell sets, weld a short piece of the bar vertically atop the implement, stack weights and lock with the collar. Some PHD units are hydraulic and can be mounted at the FEL bucket or BH bucket location and use downpressure from the FEL or BH arm.
   / Wheel weights/Ballast box vs Tire filled? #9
I totally agree. A box blade might not cost that much more, it does not stick out very far behind the tractor and is mush more useful than a box full of dead weight.
I also agree that if you have a loader you need ballast. I can get by with just the tires filled and nothing on the back, but with a full bucket it is still bouncy. When the boxblade is back there it balances very well even with a full bucket. So I suggest weights on the rears and something on the 3pt hitch.
I think rear wheel weights are a great thing, but they are too expensive for my blood. And as mentioned, you can drop them on your toe too.:D But filled tires are not risk free either. I was told that my rears were not filled. When I popped the valve off one day I got quite a bath! Geyser is the word that comes to mind.:eek:
   / Wheel weights/Ballast box vs Tire filled? #10
I can imagine George! Any chance anyone was around to watch? I think I would have fallen over laughing myself. Laughing with you of course!
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
CFG Industrial QK18R (A50121)
CFG Industrial...
2013 GMC 3500 HD Service Truck (A50515)
2013 GMC 3500 HD...
(2) Anchor Hedge Posts (A50515)
(2) Anchor Hedge...
Kubota L2501D 25HP Utility Loader Tractor (A50322)
Kubota L2501D 25HP...
