Wheel VS Frame weighs...what's up?
   / Wheel VS Frame weighs...what's up? #21
Re: Wheel VS Frame weighs...what\'s up?
<font color="blue"> Kubota weight box has 600 pounds of lead in it. </font>
Junkman
I thought there was a special notice with my <font color="orange"> Kubota </font> weight box that limited the weight to less than 500 lbs for the BX series tractors. /forums/images/graemlins/confused.gif
   / Wheel VS Frame weighs...what's up? #22
</font><font color="blue" class="small">( <font color="blue"> Kubota weight box has 600 pounds of lead in it. </font>
Junkman
I thought there was a special notice with my <font color="orange"> Kubota </font> weight box that limited the weight to less than 500 lbs for the BX series tractors. /forums/images/graemlins/confused.gif )</font>
The box has a label that <font color="green">suggests </font>no more that 300 pounds. I see it as if it can handle the weight, then use the weight. I believe that it more closely resembles the weight of the backhoe....
   / Wheel VS Frame weighs...what's up? #23
</font><font color="blue" class="small">( I guess the issue is settled in my mind. I am not going to worry about my B2910 having foam-filled tires on the front and liquid filled on the rear...and if I do get a set of bar tires for the BX2200, I am going to get them foam filled and not feel guilty about it. )</font>
Might be a stupid question, but if you fill them with foam can you ever get the tire off to replace it?
<font color="blue">Might be a stupid question, but if you fill them with foam can you ever get the tire off to replace it?
</font>
The place where I got them foam filled told me it was no big deal, they just cut them off the wheel...sounded simple, but I have not seen it done...
Ingersoll Rand Air Compressor (A52377)
Ingersoll Rand Air...
2011 Ford Econoline Cargo Van (A54814)
2011 Ford...
CAT CS563 (A47477)
CAT CS563 (A47477)
SKID STEER FORKS (A53843)
SKID STEER FORKS...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
