Spreading your rear wheels will be more cost effective and stability effective than installing wheel spacers.
It's not too bad the way it is, but having it more stable is a plus
My Kubota L3560, about the same size as your JD 3046R, has variable rear tread width from
52.2" to 57.7" with R4 tires. Your Deere should have about the same adjustability. (Tread width is from center line of tire to centerline of opposite tire. Outside to outside width will be wider.)
I am NOT an expert on Deere compact tractors.
John Deere 3046R
2014 - 3R Series
Compact Utility tractor
Previous model: John Deere 3720
Series back: John Deere 3039R
Manufacturer: John Deere
Factory: Augusta, Georgia, USA
John Deere 3046R Engine:
Yanmar 1.6L 3-cyl diesel
John Deere 3046R Power:
Engine: 46 hp [34.3 kW]
PTO (claimed): 34.1 hp [25.4 kW]
Capacity:
Fuel: 11.8 gal [44.7 L] (Cab)
13.5 gal [51.1 L] (ROPS)
Hydraulic system: 6.8 gal [25.7 L]
Front axle: 5.1 qts [4.8 L]
3-Point Hitch:
Rear Type: I
Control: position control
Rear lift (at ends): 2530 lbs [1147 kg]
Rear lift (at 24"/610mm): 2200 lbs [997 kg]
Front Hitch: 0
Front lift (at ends): 1300 lbs [589 kg]
Front lift (at 24"/610mm): 815 lbs [369 kg]
Power Take-off (PTO):
Rear PTO: independent
Clutch: electro-hydraulic
Rear RPM: 540 (1.375)
Mid PTO: independent*
Mid RPM: 2100
Dimensions & Tires:
Wheelbase: 68 inches [172 cm]
Weight: 2900 to 3570 pounds
Front tire: 7.00-14
Rear tire: 11.2-24
Mechanical:
Chassis: 4x4 MFWD 4WD
Final drives: helical gear
Steering: power
Brakes: wet disc
Cab: Two-post foldable ROPS. Optional cab with air-conditioning.
Hydraulics:
Type: open center
Capacity: 6.8 gal [25.7 L]
Pump flow: 8.6 gpm [32.6 lpm]
Total flow: 13.9 gpm [52.6 lpm]
Steering flow: 5.3 gpm [20.1 lpm]
Page information:
Last update: August 23, 2018
Copyright: Copyright 2018 TractorData LLC
Contact:
Peter@TractorData.com
