Wheel Spacers on Yanmar YT235
   / Wheel Spacers on Yanmar YT235 #1
abunchofidiots
Mt. Sidney, VA
Yanmar YT 235
I added a pair of Bro-tek 3" wheel spacers last night. So far, so good. The response time and customer service from Richard has been really good. Most places do not have anything listed about YT235s or Yanmar in general for their wheel spacers.
Before
One Side
Witness Marks
Final Width
   / Wheel Spacers on Yanmar YT235 #2
That really widened the stance on her,
looking at the photo with the witness marks brought up a couple of questions in my mind.
1) did you use a thread locking compound on those studs?
is it recommended or not?
2) if those studs where just a bit longer it would be nice to put a nyloc nut on them as a lock nut
any thoughts?
I don't need spacers as my rims are adjustable, just curious.
1. The instructions did call for high strength (red) thread locking compound on the studs.
2. I'll check the witness marks every 2 hours for a bit, then every oil change. If they move at all, I'll probably at an warping/interference nut on the inside.
When I talked to Richard today about the outer nuts, he recommended thread lock on those as well. I'll likely just use split lock washers if the outer witness marks move. Inside and outside marks are easy to check now. Not to mention there is room to remove the three point arms to hook up the B75 backhoe.
   / Wheel Spacers on Yanmar YT235 #4
how much was the spacers? did you have to call them to order them i cant find them on the website
2020 Westfield MKX 100-83 Auger with Swing Hopper (A52748)
2020 Westfield MKX...
Year: 2012 Make: Honda Model: Pilot Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A51694)
Year: 2012 Make...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2015 Chevrolet Silverado 2500HD (A52748)
2015 Chevrolet...
