Wheel Spacers on a RK25
/ Wheel Spacers on a RK25 #1
Bert the Bard
RK25
New tractor owner here.
I have a front end loader on the RK25 but I had a couple butt pucker moments on an incline that I didn't feel was very steep at all.
Any RK25/TYM T25 owners have any recommendations for size of wheel spacers, brand, and where to get them?
Should I get a 3, 4, or 5 inch spacer?
/ Wheel Spacers on a RK25 #4
Good point.
A quick google search indicates not to go above 2" as that may cause undo stress on the axles/frame. I have seen a few farmers around here with their tractors spread out 4-5" (fords and john deere's).
Adding tire ballast seems to be a good idea for hilly areas. Some even suggest turning the rims to the outside, so I'm guessing that means remounting the tires for that.
I'm interested in the ideas that will come up here. One property I plan to take my Kioti to has a lot more hilliness than others.
I try to be pretty careful when moving around some of the hilly parts of our farm and yes I feel the pucker every now and again as a wheel or two comes off the ground. Mine have happened when using the FEL. I keep it near ground level and am prepared to drop it should i need to. I also always have something on the back for ballast.
Note edited to include this: Just read on a summit tractor thread (on TBN) about wheel spacers that the manufacturer do not approve of spacers and may/will void the warranty on issues related to it (it mentioned the added strain on the tractor).
/ Wheel Spacers on a RK25 #5
First option is to set rear wheels at the widest possible setting. Since that is factory option should not have any effect on warranty. Second is wheel weights since they add minimal load stress to axles and housing since weight is supported by rims.
/ Wheel Spacers on a RK25 #7
your right switching them is easier... :rolleyes: don't know what I was a thunking..
/ Wheel Spacers on a RK25 #8
Elgin Pelican Street Sweeper (A61568)
Elgin Pelican...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A61165)
2000 Volvo VNL...
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2005 Sterling Acterra Tender Truck (A63118)
2005 Sterling...
