Wheel spacers for Toolcat
/ Wheel spacers for Toolcat #1
60047
Still searching
Does anyone make wheel spacers for Toolcats? I use drove one for the first time. Solid machine, though I would prefer just a touch more stability.
/ Wheel spacers for Toolcat #2
Should be no problem being that the newer ones are a 6x5.5 bolt pattern. The suspension makes it feel like it is tippy but I was surprised at how much weight I had hanging to one side (tree in grapple) and it stayed planted. Tractors have no suspension so the feel different.
/ Wheel spacers for Toolcat #3
Any wheel spacer will work if it is the right bolt pattern and center hole:
Or for 5 bolt:
I never felt like they were needed, maybe it is the suspension that you are not used to:
/ Wheel spacers for Toolcat #4
You would have to measure tire clearances F/R because of the AWS. The 29" tires will have less room and the big turfs are 2"wider and will have even less.
/ Wheel spacers for Toolcat #5
Love to find spacers for my narrow Mitsubishi.
(preferably at reasonable price)
While I've checked around, I'm surprised that nobody recognizes the SAE specs that I give them.
(From my parts manual I get them to be W8 X 18 rims.)
Heck I can't ship a rim 1/2 way across the country simply to get a quote. (plus I have only 2 rims and they have tires mounted and live on my tractor)
/ Wheel spacers for Toolcat #6
Also, one thing to mention. Spacers on a solid axle like a tractor does not adversely affect suspension geometry as they don't have suspension. The Toolcat has independent suspension with A-arms so moving the tires more outboard would change the leverage applied to the A-arms. Being that the Toolcat can lift 3000 lbs and do that while traveling over rough terrain, I would really be careful with spacers. You would be adding more force onto the A-arms, ball joints, tie rods, and stop pads that carry that load. Just my $.02
2009 Ford E-350 Cargo Van (A64556)
2009 Ford E-350...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
2013 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2013 International...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
2006 Hypac C530AH Pneumatic Wheel Compactor (A64553)
2006 Hypac C530AH...
2014 FREIGHTLINER M2 FLATBED (A67148)
2014 FREIGHTLINER...
