Wheel spacers for my JD 750
   / Wheel spacers for my JD 750 #11
Guys I have made a few sets of wheel spacers and I might be able to help you out if your interested. The ones I have done so far were for a chevy 3/4 ton, ford 3/4 ton and a few quads. I need to know your bolt hole pattern and the inner diameter for clearing the hub.
Here is a pic of one of the quad wheel spacers
   / Wheel spacers for my JD 750 #12
Go to a Yanmar dealer,buy the adjustible 24 " wheels that fit your JD 750 which is the same tractor Yanmar made back then (forgot the model but should be easy for you to find out). Paint them JD yellow after you adjust them to your liking. They are similar to the wheels that came with the 850's The spacers constantly come loose or the ones I had did anyway and at the time (mid 80's) there was a company making spacers for this application that I purchased from. (only made up to 1.5") Expensive, yes but in relation to your neck, maybe not so.
Try Hoye Tractor Parts for the wheels should you decide to go that way and you have no Yanmar dealers in your area. (Not sure there are any in the states anymore)or go the duals for $700 more as you must also make a couple of tire purchases.
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
2011 Chevrolet Colorado LT Pickup Truck (A50323)
2011 Chevrolet...
FUEL TANK (A50854)
FUEL TANK (A50854)
Unused Delta Crash...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
