Wheel spacers for a 2305
   / Wheel spacers for a 2305 #1
GordNovo
near
Hello,
We've recently refinished a dyke around our property to make it passable with the tractor, but the slope is a little steep in a couple of spots. From what I've read, loading the tires is a good option but I'm concerned that the extra weight will cause some problems for us in spring, since we're in a low-lying area and the weight of the tractor is already a bit of a concern for me. Does anyone know if I can add wheel spacers to a 2305? If so, I'd be grateful if you could recommend a supplier. From what I've read, widening the stance is a good alternative to extra weight. I'm using the standard turf tires. In the winter I'm running chains. I've also heard of people turning their tires around to wide the stance. Is this do-able on my 2305 as well?
Thanks!
   / Wheel spacers for a 2305 #2
If you haven't read this http://www.tractorbynet.com/forums/jd-owning-operating/96452-hub-spacers.html, give it a read.
As far as swapping your wheels side to side, your manual addresses this:
Using Optional Rear Cast Iron Wheel Weights
1. Mount rear wheels in the wide position for improved stability.
So, per your manual, you can swap side to side. Read the section on ballasting your tractor...that's where I found the statement above. You can also add wheel weights which can be removed as required.
I swapped my fronts. This resulted in a noticable improvement on slopes.
Thanks Roy! You've opened up some options to consider!!
Just read the manual again... Presumably, the front and rear tires are currently mounted in the narrow position.
I think I'll start by swapping the fronts and rears and see if I notice an improvement as it loooks like the wheel spacers are a fairly expensive option. I've sent an email to Unverferth just to find in the mean time.
Normally, I wouldn't bother looking at changing the tractor setup, but I've got this little voice in my head telling me that I should be increasing the stability before the grass cutting season starts this year!
Thanks again!
   / Wheel spacers for a 2305 #4
Gord,
Deere makes spacers that will fit the 2210/2305. I believe they are the same as on the X series.
   / Wheel spacers for a 2305 #5
JDFANATIC said:
Gord,
Do they make them for some of the other units too?
Well I was able to flip the front tires around, but the rears were already installed in the wider stance, which I think is odd since the valve stem is now on the in-side of the rim on the front and on the out-side of the rim on the back.
It must've come from the factory/warehouse like this, as I don't think the dealer would've rotated them prior to delivery.
Gord
Well I talked to my local JD dealer today. The senior parts guy said he looked high and low and could not find any spacers for 2210, 2305, or the X-Series tractors. He said he even searched the newest parts books for the new X-Series and he went back to 2003 for the others.
JDFanatic, you don't by chance happen to have a part number available?
Thanks all!
Gord N
   / Wheel spacers for a 2305 #8
Here's the skinny:
BM18021 Wheel Spacer Kit (425, 445, 455)
For all Wheel Steer Tractors when Installing TY15956 Chains.
Not for X-Series Tractors.
JDEERE2210 has them on his 2210.
   / Wheel spacers for a 2305 #9
Gord
Yep that sounds correct. As it was for all my previous tractors.
   / Wheel spacers for a 2305 #10
JDFANATIC said:
Here's the skinny:
I have two sets and run them on the front and rear of my 2210. I will try and get some pictures. I did find them available on ebay see item 230109935692
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
John Deere Z930M (A50121)
John Deere Z930M...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A52748)
GALAXY - SET OF...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
TRUCK FLATBED (A52472)
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
