Wheel removal 1938 John Deere Model A
   / Wheel removal 1938 John Deere Model A #1
elsueno
Madras, OR
John Deere / Model A
Total novice here with tractors so please bear with me.
I have a 1938 John Deere Model A tractor and am in the process of replacing the front tires. I have two new 5.50 x 16s.
I raised the front of the tractor and removed the 3 wheel bolts expecting to be able to pull the wheel and then change tires. Not so.
Help is much appreciated on how to proceed.
Thanks!
   / Wheel removal 1938 John Deere Model A #2
Loosen the wheel bolts about a turn or two and drive it in circles.
   / Wheel removal 1938 John Deere Model A #3
Agree with oldpilgrim. Wheel is stuck to hub. Driving it around briefly with bolts loosened should break it loose. You can also spray some penetrant around the loose bolts to help release it from the rust. Or try tapping the back of the rim with a 2-3 lb. hammer.
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
CFG Industrial SAII100 (A50123)
CFG Industrial...
