Wheel removal 1938 John Deere Model A
   / Wheel removal 1938 John Deere Model A #1
elsueno
Madras, OR
John Deere / Model A
Total novice here with tractors so please bear with me.
I have a 1938 John Deere Model A tractor and am in the process of replacing the front tires. I have two new 5.50 x 16s.
I raised the front of the tractor and removed the 3 wheel bolts expecting to be able to pull the wheel and then change tires. Not so.
Help is much appreciated on how to proceed.
Thanks!
   / Wheel removal 1938 John Deere Model A #2
Loosen the wheel bolts about a turn or two and drive it in circles.
   / Wheel removal 1938 John Deere Model A #3
Agree with oldpilgrim. Wheel is stuck to hub. Driving it around briefly with bolts loosened should break it loose. You can also spray some penetrant around the loose bolts to help release it from the rust. Or try tapping the back of the rim with a 2-3 lb. hammer.
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2024 Kubota RTV520D-AS (Dothan, AL) (A50123)
2024 Kubota...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
2020 RAM Promaster City Mini Van (A53117)
2020 RAM Promaster...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
