Wheel motors on - starting to get anxious now...
   / Wheel motors on - starting to get anxious now...
RegL said:
Do you notice a lot of difference in speed.
There is a noticeable difference when transporting the tractor -- top speed is slightly more than 5MPH now. However, you don't notice a speed difference when using the loader, or using the rough-cut mower, etc. You adjust to just giving it more treadle to work as quickly as before.
If you're not specifically looking for hill-climbing ability, or will use it primarily for mowing a smooth lawn, I wouldn't recommend going to this large of a motor (22.7ci). Someone else went to 17.x ci CharLynn S series like this, and he even adjusted his throttle cable to make sure he could get max speed for mowing...
All my mowing with it will be with the rough-cut, on these hillsides, so I'm one happy camper. I've found I can use the LM bucket now to haul topsoil and mulch, whereas before I had to use the smaller bucket -- so I can actually do what I need to do much faster... :)
   / Wheel motors on - starting to get anxious now... #42
Sounds like just what you were after. Good job of planning for the correct size motors for your tasks.;)
   / Wheel motors on - starting to get anxious now... #43
Good job on the selection of the wheel motors. 5MPH is still a good speed, and yet you have plenty of torque. When I was cleaning out the retention pond at Church, I could not drive up and out with the 422. I had about six people pull on a rope while I drive and came out fairly easily.
I forget, did your 425 have the newer wheel motors originally?
No, it had the same smaller displacement motors that I think yours has -- White RS series, 12.5ci
   / Wheel motors on - starting to get anxious now... #45
Aw-Shucks, do you mean after all of this it won't climb a tree:D
just kidding
congrats
   / Wheel motors on - starting to get anxious now... #46
5 MPH would be plenty fast for me. The only time I use top end speed is when I scoot up the road for a short distance. Nice job, nothing like having that extra torque when using ground engaging attachments. ;)
It's much more useful for me this way. With these new wheel motors, it's similar to your BX with only the low-speed range.
Not only did it increase torque overall, the increase is VERY noticeable when accelerating AND slowing down -- it increased the braking ability as much as it increased the pulling torque. Until you adjust to the difference, you can make the PT lurch to start or stop -- wearing the seatbelt is absolutely essential now. The torque is actually more noticeable slowing down when first using it, instead of when taking off...
I'm not sure how the optional low-speed valving that I spec'ed in influences this (you'd have to compare to one without these special valves), but it certainly is "precise" at low speeds. You can readily move the PT forward or back literally an inch at a time and hold it there with the treadle -- even on a slope -- so it's great for working with the minihoe, for example.
I haven't encountered ANY bypassing at all with these so far -- it'll spin the tires instead... whether climbing a hill, pushing or pulling hard, etc. In that regard, it performs much more like a traditional tractor. However, with true four-wheel drive (not front wheel assist), articulation and frame oscillation, and with the same size tires all around, it is still quite different than a traditional tractor. For example, I could climb the bank below my driveway, up over the shoulder and onto the driveway without spinning at all. Even as the weight shifted first mainly to the back wheels as it climbed up the bank, then back to the front wheels as they came over the apex of the shoulder, the whole thing was uneventful. If one tire should happen to break loose and start to spin, just let off the treadle (which significantly increases the torque while decreasing the speed) and it would crawl right on up and over...
All my work was done in dry conditions -- gorgeous weather in upper 70s and low 80s -- it will be interesting to see what it feels like in wet, slippery conditions... I'm already looking forward to the next trip in June! :p :D
Speaking of ponds, a guy pointed out the link to Microsoft Live's aerial views last night, and I discovered that it has relatively current (this past winter??) views of the property in Tennessee I've been clearing and working on with the PT.
Here's a view of it, with my approximate propery lines drawn in... slowly getting it ready to build! :p :)
   / Wheel motors on - starting to get anxious now... #49
Pond frontage! Here, fishy fishy fishy:)
Yep. The smaller pond has some nice LM bass in it, but I think the larger one is basically bluegill and scrub stuff -- it's pretty shallow, and has a few resident geese and mallards...
My son saw an overgrown orange "Baltimore minnow" in the smaller pond that must've been close to 2 feet long -- someone lost their bait -- it freaked him out! :D
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A58214)
2015 DRAGON 137BBL...
UNUSED PABREAK METAL BUCK SHOOTING TARGET (A57193)
UNUSED PABREAK...
UNUSED FUTURE CLG72 72" HYD CURVED LOG GRABBER (A57193)
UNUSED FUTURE...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
