Wheel Loader Tires on Tractor?
   / Wheel Loader Tires on Tractor? #1
Suburban Plowboy
FL
Kubota L3710
The front tires on my Kubota L3710 were not looking great, and one came off the rim a couple of times. They have a lot of cracks.
I decided to get new front tires.
The original tires were Goodyear turf tires, and I found out they were rated at 1000 pounds, which seemed ridiculous for a tractor that will lift at least 1500 with the loader. Also, it seemed to me that smooth tires were a bad idea for a 4-wheel-drive machine. Maybe I'm wrong.
I got myself some Carlisle tires. Now that I have them, I am seeing indications that they are really loader tires, so the manufacturer apparently had things like Bobcats in mind.
Has anyone else here used loader tires for tractor fronts? I'm wondering if there is any down side.
I don't care about marking up grass, since this tractor is used in the woods and my pasture.
   / Wheel Loader Tires on Tractor? #2
If you have a four wheel drive tractor the biggest concern is matching the overalll circumference to the original. Deviating very far will cause excessive wear in the drive mechanism. Beyond that it doesn't matter if you're running racing slicks.
   / Wheel Loader Tires on Tractor? #3
Do note that not all turf tires are equal. Lots of 4wd CUT's configured for turf come with 4-ply rated tires up front, which are not really suitable for loader work. But these sizes are typically also available in 6-ply rating, which should meet or exceed the requirements outlined in your loader manual.
The tire dude said only one of my old tires had a tube. Wonder how that happened. I guess they both started out tubeless and one developed a leak they couldn't fix.
   / Wheel Loader Tires on Tractor? #5
~10 years ago I changed the front tires on my L3710 to skid steer tires. Same height and circumference, but close to twice the psi and number of belts and load capacity as the OEM tires. No issues, I'm a happy camper. The skid steer tires where in stock, OEM's were not.
I wonder if I should run a lower psi on a tractor than a wheel loader.
   / Wheel Loader Tires on Tractor? #8
The industrial tires on my Mahindra 3015 (30HP) are so stiff that can leave all the air out of the rears and they will still stand tall. Found that out when loading on a a 60" width trailer with sides. Had to let the air out to get it on and off the trailer. :) The downside is that it rides like a lumber wagon with 10 PSI.
   / Wheel Loader Tires on Tractor? #9
A skid steer tire is a much heavier duty tire than the average tractor R4 tire. As long as the size is correct I wouldn’t hesitate to use them.
   / Wheel Loader Tires on Tractor? #10
I'm not sure I see the advantage of running skid steer tires on a tractor. I mean, sure they work... but serious overkill, and hell of a stiff ride for anything other than a 100% dedicated loader application.
2012 Ram 3500 Crew Cab Flatbed Truck (A56858)
2012 Ram 3500 Crew...
2008 Ford F-350 Lariat (A57148)
2008 Ford F-350...
2017 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2017 CATERPILLAR...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A58375)
UNUSED SET OF...
