Rake Wheel kit on a landscape rake??
/ Wheel kit on a landscape rake?? #1
TractorLegend
Platinum Member
Randle, WA
2012 DK 45HST SE w/ FEL
What does the optional wheel kit accomplish on a landscape rake? Never before used rake.
/ Wheel kit on a landscape rake?? #2
I have one on mine...no gouging or washboarding.
I have a backblade without one...wish it had one.
I use mine to spead dirt...man it works really well..nice and smooth.
Thats the bottom line
/ Wheel kit on a landscape rake?? #3
I only lower the wheels on mine for finishing or touch up work. Before that, I control the rake with position/depth/float control capabilities of the TPH. So when the full weight of the rake is needed to move heavy/bulky material, it's "wheels up".
At the end, when I want to level the job - drag the high spots into the low spots - then it's "wheels down" time.
//greg//
/ Wheel kit on a landscape rake?? #4
Without the wheels, while rolling over a uneven surface, as the front of the tractor goes up over a rise, the rear mounted rake or blade will go down and dig into a already low spot. With the guide wheels on behind the rake, the rake will only dig into the high spots and drag the debris to the low spots. Just like a road grader does with the blade located between the front and rear wheels.
On the rake I built for my garden tractor I don't have wheels. I really only use this rake for collecting branches and debris under and around the trees. It does dig into the dirt as I drive up over uneven ground. The rake I am building for the big tractor will have wheels.
/ Wheel kit on a landscape rake?? #5
here are acouple of pics of my rake and guage wheels. It keeps the rake from digging in when you go over bumps or rocks with the tractor. rake
2014 KAWASAKI KAF400B (A66091)
2014 KAWASAKI...
2014 CASE CX160C EXCAVATOR (A65053)
2014 CASE CX160C...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
