wheel horse tractor 312-8
   / wheel horse tractor 312-8 #1
PaulB50
wheel horse 312-8
My wheel horse tractor will start and run awhile then it stops. I have checked the coil,sparkplug,points,seat switch and most of the wires I can see. If I wait awhile it will start again but will stop running a little while later. I pulled the plug wire off when it stopped and there was no spark but let it sit a few minutes and it will start.
   / wheel horse tractor 312-8 #2
Welcome to TBN. :)
   / wheel horse tractor 312-8 #3
Sounds like it could be dirt in the fuel. When the engine is on it sucks the dirt into the jet and stalls it. It then floats down allowing it to start again and then cycle repeats itself. Disassemble the carb and clean and that should fix it.
Hopefully.
   / wheel horse tractor 312-8 #4
Welcome to TBN!!! If cleaning the carb does not fix it, you may find some more help in the Parts/Repairs section. :thumbsup:
2018 FORD TRANSIT T150 CARGO VAN (A54313)
2018 FORD TRANSIT...
1993 PETERBILT 362 SLEEPER (A54607)
1993 PETERBILT 362...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2003 CATERPILLAR D6R XW HI-TRACK CRAWLER DOZER (A51406)
2003 CATERPILLAR...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A55218)
2021 John Deere...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
