wheel horse 520 electrical problem?
   / wheel horse 520 electrical problem? #1
Anonymous Poster
Epic Contributor
I have a wheel horse 520. I have had to start the tractor with the start up mode on a battery charger. Last Sunday as I was mowing, the tractor just "shut down". I started it right back up but noticed that the guages and lights were not working. Tractor works fine otherwise. I checked the fuses and they appear to be fine. I am going to replace the fuses to see if the existing 10amp or 20 amp might be bad but I can't see it. I started it again last night and it runs fine but no guages or lights? Could it be the alternator? Would explain battery not charging. The battery seems fine. The guages must be a fuse? very wierd!! Can anyone help??
   / wheel horse 520 electrical problem? #2
Do you have a voltmeter? A. check the voltage w/ the engine off. B. Check the voltage as you crank the starter, C. check the voltage as the engine is running.
The off volts should be near 12
cranking should be >10
running should be 13-14
A & B low - > bad battery
C low - > bad alternator or regulator or something else in the charging system
Also check all cables and connections etc. Should be clean and tight
2018 WOOD MAXX TM 86H WOOD CHIPPER (A51243)
2018 WOOD MAXX TM...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52128)
2021 John Deere...
2010 CATERPILLAR CM1210106 ROUGHT TERRAIN FORKLIFT (A51242)
2010 CATERPILLAR...
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
Agco 4210 3pt 2 Star Tedder (A50774)
Agco 4210 3pt 2...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
