Wheel Horse 257-H charging problem
   / Wheel Horse 257-H charging problem #1
RichFC
new york
MTD and Craftsman
At idle or low RPMs it will charge but if i turn on the PTO or headlights it discharges. Also or I raise RPMs without turning anything on it does not charge. The battery is new . I just received this tractor it has been sitting in the woods for a few years. It starts right up and it has a Kawasaki FC540V engine
Gator6x4 thanks for the info! I will check it out now!
   / Wheel Horse 257-H charging problem #4
You're looking at alternator/Voltage regulator issues, depending on what it uses to produce a positive charge back to your battery. I'd also want to investigate ALL connections to/from your battery, the ground cable attachment to the frame, and any corrosion or chewed wires from sitting out in the woods for 'years'!?
Good luck.
1266 (A50490)
1266 (A50490)
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
