Wheel Horse 257-H charging problem
   / Wheel Horse 257-H charging problem #1
RichFC
new york
MTD and Craftsman
At idle or low RPMs it will charge but if i turn on the PTO or headlights it discharges. Also or I raise RPMs without turning anything on it does not charge. The battery is new . I just received this tractor it has been sitting in the woods for a few years. It starts right up and it has a Kawasaki FC540V engine
Gator6x4 thanks for the info! I will check it out now!
   / Wheel Horse 257-H charging problem #4
You're looking at alternator/Voltage regulator issues, depending on what it uses to produce a positive charge back to your battery. I'd also want to investigate ALL connections to/from your battery, the ground cable attachment to the frame, and any corrosion or chewed wires from sitting out in the woods for 'years'!?
Good luck.
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2006 Acura RL Sedan (A51694)
2006 Acura RL...
2020 VANGUARD CIMC 53FT REEFER TRAILER (A54607)
2020 VANGUARD CIMC...
1 pallet of Tool box /Pump/5 safety cones (A53117)
1 pallet of Tool...
2014 MACK GU713 DAYCAB (A53843)
2014 MACK GU713...
