Wheel compatibility between John Deere 4720 and NH TC40D
   / Wheel compatibility between John Deere 4720 and NH TC40D #1
wolfpack2
SE Michigan
JD 4520
I am looking to trade in my New Holland TC40D on a new JD 4720 Cab and would like to keep either the R4 or turf tires that I have for the New Holland assuming that the wheels will fit on the John Deere. The tires are the same size as what the 4720 comes with, but I am not sure if the bolt pattern and hub pilot are the same. Does any here know if they are the same, or can someone provide the front and rear dimensions for the 4720 wheels?
   / Wheel compatibility between John Deere 4720 and NH TC40D #2
I just measured my 4720. Rear: 8 bolt pattern, 8" bolt circle, 6" hub******Front: 6 bolt pattern, 6" bolt circle, 4.5" hub
I measured with a tape measure, but it should be close enough.
Mine measure the same, so I guess I can keep one set. Now I just have to decide which ones.
   / Wheel compatibility between John Deere 4720 and NH TC40D #4
Congratulations on the new tractor!
I pulled the trigger on the new tractor today. I decided to drop down to a 4520. I just couldn't justify the extra $1600 for 6 hp. The 4520 will still have 20 more than my current machine. I will start a new thread (with pictures) once the new tractor arrives. The dealer is estimating mid August. I was originally looking at an e-PTO, but that would have moved out the date to November.
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
2016 FORD Transit Cargo Van (A50323)
2016 FORD Transit...
2011 Liebherr L586 (A52128)
2011 Liebherr L586...
2008 FORD F150 XL TRUCK (A51243)
2008 FORD F150 XL...
