Wheel compatibility between John Deere 4720 and NH TC40D
   / Wheel compatibility between John Deere 4720 and NH TC40D #1
wolfpack2
SE Michigan
JD 4520
I am looking to trade in my New Holland TC40D on a new JD 4720 Cab and would like to keep either the R4 or turf tires that I have for the New Holland assuming that the wheels will fit on the John Deere. The tires are the same size as what the 4720 comes with, but I am not sure if the bolt pattern and hub pilot are the same. Does any here know if they are the same, or can someone provide the front and rear dimensions for the 4720 wheels?
   / Wheel compatibility between John Deere 4720 and NH TC40D #2
I just measured my 4720. Rear: 8 bolt pattern, 8" bolt circle, 6" hub******Front: 6 bolt pattern, 6" bolt circle, 4.5" hub
I measured with a tape measure, but it should be close enough.
Mine measure the same, so I guess I can keep one set. Now I just have to decide which ones.
   / Wheel compatibility between John Deere 4720 and NH TC40D #4
Congratulations on the new tractor!
I pulled the trigger on the new tractor today. I decided to drop down to a 4520. I just couldn't justify the extra $1600 for 6 hp. The 4520 will still have 20 more than my current machine. I will start a new thread (with pictures) once the new tractor arrives. The dealer is estimating mid August. I was originally looking at an e-PTO, but that would have moved out the date to November.
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
5th Wheel Dolly (A49461)
5th Wheel Dolly...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
50 CAT 5 TOOTH EXCAVATOR BUCKET (A50854)
50 CAT 5 TOOTH...
