wheel bolts
   / wheel bolts #1
Anonymous Poster
Epic Contributor
I have a B8200 4WD I was doing loader work one day I looked down and noticed one bolt missing now we hwve two is it safe
   / wheel bolts #2
Alex, I can's say whether it's safe enough for you, but it wouldn't be safe enough for me./w3tcompact/icons/smile.gif I'd be hunting for some replacement bolts.
Bird
   / wheel bolts #3
Ditto. They're on there to begin with because you need 'em, in my opinion.
Mark
   / wheel bolts #4
My manual says to torque the wheel bolts after driving 240 yards then every 50 hours thereafter. The torque specification is pretty tight (208 ft lbs on my tractor). My torque wrench isn't that good. Where do you get one for that range?
Answer to your question: Go buy the correct bolts before you use the tractor. It should get you home if the other bolts are not loose, but if it only has 3 bolts, I would walk home. /w3tcompact/icons/frown.gif
   / wheel bolts #5
Wen how much money do you want to spend a good rule of thumb on a good torque wrench $1.00 for each ft.lb. so for about $250.00 you'll be uptown. or about $125.00 for a cheepie with tools you get what you pay for. If your tires aren't exactly 208 ft. lbs. they won't be going anywhere. But I guess it's better safe than sorry.
Oh sorry almost didn't answer your question Snap-on tools.
I've had good luck with them but I also use mine quite a bit.
Gordon
   / wheel bolts #6
we'll since their metric I have to order them from kubota.
Alex "Laserman" Karpinski Kubotas rule :-()
   / wheel bolts #7
Most local hardware and auto parts stores have a selection of Metric bolts. I would check first before ordering.
Dave
   / wheel bolts #8
Maybe I am just old school or just old farmboy but I cannot see the reasoning to go buy a torque wrench just for that. If you keep them very snug and check them regularly, and assuming you are not a very, very large person that would overtighten them, thats a lot of torque and I don't think I could, you will be alright, safe, and have a little money left over to spend on the 'bota instead of a torque wrench.
   / wheel bolts #9
P.S. Do for sure replace the bolt. Although I don't think the torque has to be exact but I think they put on a specific amount of bolts for a reason.
   / wheel bolts #10
Wen, Gordon is about right on the price. Torque wrenches in that range are not hard to find; just hard to pay for. The half inch drive 25-250 ft./lb. torque wrenches my brothers sell run $213.95 for the fixed head and $216.95 for the flex head. And naturally I'd have to recommend you use one since that's what the manual says, and my brothers sell them, but I just use my little air impact wrench./w3tcompact/icons/smile.gif
Bird
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
2001 CHEVROLET TOW TRUCK (A52472)
2001 CHEVROLET TOW...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
