wheel bolts for a ford 1600
   / wheel bolts for a ford 1600 #1
dasnapeth
ford 1600
While tightening the wheel bolts for my mother in laws Ford 1600 I snapped off the head of the bolts. What is the size/thread pitch for the bolts? Easily found at local hardware store or special order item? Thanks in advance
The new guy
   / wheel bolts for a ford 1600 #2
Front or rear? I have a Ford 1600, its metric everywhere. A real good hardware store might have them. I believe metric bolts are stronger than a SAE 5, but weaker than a SAE 8.
Whoops sorry, its the front wheels
   / wheel bolts for a ford 1600 #4
Okay, just went to the Ford shed. The 1600 front wheel bolts say 3 F and 8.8. Im not real sure how to determine the pitch. I could get you a length, but my tractor has front wheel weights and they block everything.
   / wheel bolts for a ford 1600 #5
If this helps....I also have a Ford 1710. Its very close in size to the 1600. I don't have a 1600 owner's manual, but I do have a 1710 owners manual. It states for a 2wd, 1710 ( or all 1600s) the front wheel bolt torque should be 43-54 lb ft. Being the bolts are similar, I think thats a safe figure to use on a 1600.
   / wheel bolts for a ford 1600 #6
Hi! The best remove one and you go in a Good autopart or tractor dealer with the bolt you can have the good replacement. I use a metric threader set for find bolts size. Good Luck! Oldmech.
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A53426)
2020 INTERNATIONAL...
UNUSED FUTURE SF60 HYD MAST W/ 60" FORKS (A51248)
UNUSED FUTURE SF60...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A53472)
FIRESTONE 9.5L-15...
2011 Kia Forte Sedan (A51694)
2011 Kia Forte...
197711 (A51244)
197711 (A51244)
