Wheel Bolt Torque
   / Wheel Bolt Torque #1
centex
Lampasas, Texas
JD 4700
My service manual specifies 65 - 80 lbs-ft torque for the wheel bolts (JD 4700) but the operator's manual specifies 114 lbs-ft. Does anyone know which is correct? I found the left bolts loose yesterday - both front and rear. The right bolts were still tight.
   / Wheel Bolt Torque #2
The owners manual for my 4300 also says 114 ft-lbs. Seems like a reasonable torque for bolts that size. When I first received my 4300 I backed all the wheel lugs out one at a time, applied a little red loctite, and re-torqued to spec. Have not had any sign of loose lugs since. Of course I don't know if the lugs would have loosened up without the loctite. Good luck.
2020 Chevrolet Express (A50120)
2020 Chevrolet...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
