What's your favorite tool for cutting net wrap.
   / What's your favorite tool for cutting net wrap. #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
I've removed net wrap with everything from a box cutter to a machete. I've even ripped it off with my hands when the netting was fine enough. Every method has had advantages and disadvantages. I guess my two favorites are a smooth bladed pocket knife and a crow bar. The pocket knife dulls quickly and I carry a carbide sharpening steel with me. With the crow bar, I use the claws to rip off about five inches at a time till I'm across the bale.
If anybody has a better method, please tell about it.
   / What's your favorite tool for cutting net wrap. #2
That's all I've ever used is the knife blade on my Gerber multi-tool. Mind you, I'm only cutting a single round bale every 10-11 days.
How many bales are you opening that would dull a blade so quickly? Regular mesh? Silage Wrap?
I like to keep all of my blades sharp for whenever I need them, but only truly sharpen them all around twice a year... not only because a dull knife isn't a knife but it impresses other people when I hand them one of my knives and warn them that it IS sharp. I love the look on their face when they use a blade that really is sharp as to what they've 'put up with'.
   / What's your favorite tool for cutting net wrap. #3
Sheffield knife with replaceable utility knife blades. My go to pocket knife.
Wagtail,
I feed up to four bales at a time depending on many factors. I've used a utility knife blade in a pocket knife like RickB describes, too. They didn't stay sharp very long either.
   / What's your favorite tool for cutting net wrap. #5
I don't use bales and I'm not sure what kind of wrap you're talking about, but if you have an issue with blades dulling, would a ceramic blade help? I noticed HF has a ceramic blade utility knife for $10 or so.
   / What's your favorite tool for cutting net wrap. #6
I just unwind the wrap with the bale in the air on the spear.
   / What's your favorite tool for cutting net wrap. #7
Saw with the serrated blade on a multi-tool, several bales a day.
Some haylage bales with plastic as well as net wrap some dry with just the net wrap.
Using a squeeze grapple, just net wrap bring the bale to easy reach and saw down.
With plastic wrap set it down cut a circle out of the top slice and saw down.
   / What's your favorite tool for cutting net wrap. #8
Don't use your tiller, it won't cut it very well. I found that out tilling a new garden for a new customer in what turned out to be an old pasture/feedlot. I spent more time cutting net than I spent tilling.
   / What's your favorite tool for cutting net wrap. #9
I use a sheetrock knife with extra blades in the handle. As soon as it gets dull, I replace the blade. Easy Pleasy!!!
   / What's your favorite tool for cutting net wrap. #10
I don’t feed hay, but if a knife wasn’t working well I’d probably use my cordless grinder.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
3410 (A47477)
3410 (A47477)
2016 Chevrolet Express 2500 Passenger Van (A55973)
2016 Chevrolet...
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
Air Compressor (A54816)
Air Compressor...
