Tires What's with the tires???
   / What's with the tires??? #1
WVnewbe
West Virginia
Kubota L5240
I purchased a new 5240 about two months ago. I have had two front tire flats over this time period. After looking over the tire I found that a stick had punctured the tire both times. I grew up operating tractors and can't remember ever getting a flat from a stick....Are these new tires to soft? Are they two thin?
   / What's with the tires??? #2
Sticks have grown up since..... they are a lot tougher now days.... :D :D
   / What's with the tires??? #3
Sounds like you need to install tire sealant in your tires. That should fix your flat problem on any hole in the future up to about 1/4 inch in diameter.
   / What's with the tires??? #4
What type of tires are on your tractor. I had a problem with flats on the front R4’s of mine until I put tubes in. That solved most of my problems.
MarkV
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
2022 JOHN DEERE 317G SKID STEER (A51242)
2022 JOHN DEERE...
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
