Oil & Fuel whats up with my 3520's fuel guage?
   / whats up with my 3520's fuel guage? #1
jmt1271
Platinum Member
MO
Kubota L2501
I have about 3/4 tank in the tractor. I parked it for a while and just went to put it away. The light started flashing as the guage slowly went from 3/4 to empty in about 3-4 seconds.???? now it sits on E. No sign of a leak at all. Any ideas?
   / whats up with my 3520's fuel guage? #2
JMT
Is there really 3/4 of a tank in there or have some of the neighborhood "vandals" been helping themselves to your fuel? For what it's worth, I am replacing the entire instrument cluster (under warranty) on my 3520 because of a defective hour meter. It's not that big a stretch to think that there might be other problems with the clusters...
BILL
   / whats up with my 3520's fuel guage? #3
I have a 3520 also and the same thing happened to me the other day. But the strange thing is it had still had fuel in it. I shut it off and restarted it and then it read 3/4 a tank. I had it on level ground in fact I was changing over from my blade to put on the mower and when I jumped back on the seat the fuel light was on. So know it makes me wonder should I trust the fuel guage or not?
wesc1
Wes, did it straighten itself out? I will go check mine and see if it is still doing it. hate to have to take it to the dealer over something like this.
   / whats up with my 3520's fuel guage? #5
The 4X20 had the exact same problem,It was a batch of bad fuel sending units. I went thru 3 until mine worked correctly.
Jim
Is there a recall? What do I need to do, assuming the sending unit is the problem. What exactly did your 4x20 do when the unit went bad?
thanks.
   / whats up with my 3520's fuel guage? #7
I went ahead and mowed for about 2hrs and it didn't show up and again the next day it worked fine. So I don't know if it is working fine or not. I just read your post and thought there might be something going on here. I got my tractor last year around Aug just wondering when you got your tractor. If there is going to be problem just want to nip it in bud. Did your clear up after shutting it off and restarting it also? or is you light on all the time?
   / whats up with my 3520's fuel guage? #8
Did I miss something? When did ANYBODY start trusting a Deere/s fuel guage?
I bought mine about 2.5 months ago.
Its not about "trusting a JD fuel guage" I just want to make sure there arent more serious electrical issues.
   / whats up with my 3520's fuel guage? #10
Don't worry, it just seems there is no end to the fuel guage saga....
2015 Ford Escape SE SUV (A55853)
2015 Ford Escape...
5ft Serrated Hydraulic Dozer Blade Skid Steer Attachment (A55851)
5ft Serrated...
John Deere 2305 Tractor - 575 Hours (A55314)
John Deere 2305...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2003 International 7400 T/A Heil 12 Yard Dump Truck (A55852)
2003 International...
2019 John Deere 310L EP 4WD Backhoe (A53485)
2019 John Deere...
