I use Loctite 567 which is a hi-pressure thread sealant....not just a lubricant....it needs to cure first however....I had a leak in an NPT hose fitting...this cured it....twister
I used something similar, called permatex #54540 pneumatic and hydraulic sealant to seal a ORB straight threaded fitting that was machined improperly, not allowing the gasket to seal. Worked great. I now use it for most all my hydraulic connections. Amazon has it for $26. NAPA charged me $37.
/ Whats the trick to hooking up hydraulics and not having leaks
I use great white Teflon paste. Non of mine have ever leaked. They are all NPT threads. The stuff is cheap and available at Lowe's. I am sure it is not as good as some of the higher priced more specific Hydraulic sealers mentioned here, but it has worked for me on my hydraulic projects.
Teflon paste sealant took care of 5 out of 6. The 6th one which was the really bad one worked with 3 wraps of Teflon tape. Careful not to have any past the threads and wrapped clockwise facing the threads.
