What's the timeframe for spraying weed killer on a newly sprigged field?
   / What's the timeframe for spraying weed killer on a newly sprigged field? #1
warhammer
Central Texas
Kioti DK45SE HST
Fertilized and sprigged three weeks or so ago. There are broadleaf weeds coming up all over with one large approx 1/4 acre spot having a pretty good patch.
I was reading the 2-4,D label and it says not to spray until the hay has been cut a time or two.
Should I spot spray the weeds with 2-4,d or just let it all grow or....?
Warhammer
   / What's the timeframe for spraying weed killer on a newly sprigged field? #2
After I sprigged last year, I was told by the Ag extension service that I could spray with a 1 or 1.5 pint/acre rate after the sprigs had runners 4" to 6" long. I ended up not spraying and brushhoged them down a couple of times.
Did your sprigs come in ok with just the brush hogging?
Warhammer
No thoughts on this from the braintrust?
Attached is a new pic. This is one month after sprigging.
Warhammer
Warhammer
   / What's the timeframe for spraying weed killer on a newly sprigged field? #5
I'd give my local extension agent a call and ask for his advice.
I'm assuming you sprigged bermuda so, personally, I'd be a little reluctant to hit it too hard with 2-4-D this early. If you have the time and energy, mowing it highish and often can usually take care of a lot of the weed problem. At least it might buy you some time until later in the year when you can go get mad with the sprayer.
   / What's the timeframe for spraying weed killer on a newly sprigged field? #6
Warhammer, that patch actually looks pretty good. I'd do like Frank recommended and hit with a high brush hog. I've done this for a few years when spraying wasn't in the plan. I will say that if you end up with arrowleaf clover cutting high seems to only make it worse. I'd hold off on spraying but that's just me. I wouldn't consider my opinion part of that "braintrust":rolleyes:
Jay
   / What's the timeframe for spraying weed killer on a newly sprigged field? #7
Warhammer
Yes they did. There where some weeds, but it kept most of the competion down.
   / What's the timeframe for spraying weed killer on a newly sprigged field? #8
After I sprigged Tifton 85, I was told by the grower to hit it with 4pts per acre of Grazon P+D. It did fine. 2-4-D doesn't hurt bermuda grass. On a related subject...Has anyone used Grazon Next? I used it this year and haven't decided yet if it's as good.
Its amazing how fast it grows. The difference in time between the two pics I have posted is a week and it looks like its about doubled.
Warhammer
Jay
I am going to give the high mowing a go. Thanks for the reply.
Warhammer
2020 Chevrolet Tahoe SUV (A52377)
2020 Chevrolet...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
Light Tower (A52377)
YANMAR ViO45-5 EXCAVATOR (A51406)
YANMAR ViO45-5...
SET OF (3) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (3) ALCOA...
