Price Check whats the pricing on the DK45SE HST?
   / whats the pricing on the DK45SE HST? #1
leveled
NY
MX5100HST FEL, KX121 MINI X GEHL 6640 Ferris IS3200z Kubota 1100RTV
I am debating this against a kubota. Thanks
   / whats the pricing on the DK45SE HST? #2
Are you buying new or is used an option? There's one near me for 18,900 with 132 hours on it. Prob get it down a bit more....
I don't know what new prices are so this may or may not be all that great.
   / whats the pricing on the DK45SE HST? #3
With loader and hooks welded on.
40se hst 20,100.00
45se hst 21500.00
Delivered 150 miles.
wow thats considerably lower than the price of the L4240. How does everybody like there kioti? also where can I get the specs on the loader on the kioti.
   / whats the pricing on the DK45SE HST? #5
Lift Height 107.8"
B - Clearance with Attachment Level 105.5"
C - Clearance with Attachment Dumped 79.9"
D - Reach at Maximum Height 16.1"
E - Maximum Dump Angle 73ー
F - Reach with Attachment on Ground 73.6"
G - Attachment Rollback Angle 30ー
H - Digging Depth Below Grade 6.7"
J - Overall Height in Carry Position 52.7"
L - Depth of Attachment (to back of inner shell) 20.7"
M - Height of Attachment 22.6"
N - Depth of Attachment (to pivot pin) 25.9"
Lift Capacity to Full Height at Pivot Pins 2,761 lbs
Breakout Force at Pivot Pins 3,727 lbs
Relief Valve Setting (Loader Control Valve) 2,556 psi
Rollback Force at 500mm forward on the ground 4,633 lbs
Rated Flow (Tractor System) 10 GPM
Lift Cylinder Bore 60 x Rod 35 x S.t 485
Bucket Cylinder Bore 55 x Rod 30 x S.t 525
Attachment used for Specification 72"
Raise Boom 7.6(1,500rpm),5.7(2,000rpm),4.5(2,600rpm)
Lower Boom 4.9(1,500rpm),4.8(2,000rpm),4.8(2,600rpm)
Dump Bucket 6.2(1,500rpm),1.9(2,000rpm),1.5(2,600rpm)
Retract Bucket 2.3(1,500rpm),2.2(2,000rpm),2.1(2,600rpm)
   / whats the pricing on the DK45SE HST? #6
Also.....
Tractor is around 200 lbs heavier. (sorry 'bout that)
1 set of remote hydraulics standard.
BTI
now I am thinking that maybe I should get this and the backhoe, what would this cost.
The 4240 weighs 3671 and the kioti weighs 3881, I do not see the 1000 pounds unless it is all in the loader.
   / whats the pricing on the DK45SE HST? #9
Where are you from?
Western, NY Erie county.
2006 MACK CV713 KILL TRUCK (A52472)
2006 MACK CV713...
New Holland LX885 Skidsteer (A51573)
New Holland LX885...
2018 RoGator 1100C (A52748)
2018 RoGator 1100C...
198367 (A51243)
198367 (A51243)
1977 CATERPILLAR D6D (A52472)
1977 CATERPILLAR...
