what's the difference between the x595 and 2210 ??
   / what's the difference between the x595 and 2210 ?? #1
megotatractor
New Richland, Minnesota
JD 2210
what\'s the difference between the x595 and 2210 ??
/forums/images/graemlins/confused.gif
   / what's the difference between the x595 and 2210 ?? #2
Re: what\'s the difference between the x595 and 2210 ??
The 2210 is a subcompact tractor so it is a little more heavy duty. It has a 2 range hydro trans compared to the X's single range, better for loader work probably safer too with the roll bar. The 2210 has one less horsepower than the X. For the money I would get the 2210 since it's more like a real tractor unless you need to mow under trees. I know we have a new 2210 and an X series if ya want send me a PM and I can get a quote for you at the dealer I work for.
   / what's the difference between the x595 and 2210 ?? #3
mewantatractor,
yellowscocks93 hit it right on the head. I just ordered the X595 and therefore have done quite a bit of research on your exact question, so I will share my results. The X595 is meant to be used as a garden/lawn tractor but can be equipped with some of the more tractor like implements. The 2210 is a mini sub-compact tractor that will also do a fine job of mowing you lawn. Here are the differences good or bad:
X595 can be equipped with a rear PTO and 3ph, 2210 both are standard
X595 has two "turn signal" style hydraulic levers next to the steering wheel and no rock shaft lever for the 3pt, 2210 has a more conventional joystick style lever for the hydraulics plus a rock shaft lever.
So it really comes down to what your main function will be, for me it was mowing the lawn hence my decision to get the X595.
I hope this helps, but if you have any specific questions...
Waldo
today I made it to a dealer to see these models in person. The 2210 sits on the same tires as the X595 but it is noticeably larger esp. the operator platform. Since I plan on moving gravel, sand, rocks and dirt I have choses the 2210. the quote I got ; 2210 with HDAP tires, FEL, MMM, rear blade and tiller-- $15,300
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
2018 VOLVO VNL SLEEPER (A51222)
2018 VOLVO VNL...
2003 DITCH WITCH 3700 RIDE ON TRENCHER (A51242)
2003 DITCH WITCH...
E-Z Trail Head Cart (A50514)
E-Z Trail Head...
