What's the difference between the bh760/bh860 backhoes?
   / What's the difference between the bh760/bh860 backhoes? #1
madpuma13
Centex
Branson 4720
I'm about to purchase one of these for my 4720ch. Looking at the generic spec sheets doesn't show that they are that different.
One digs a little further down, another has a little more digging force.
But there doesn't really appear to be anything that makes the 860 stand out as being stronger/better than the 760.
Any help or experience would be appreciated!
   / What's the difference between the bh760/bh860 backhoes? #2
Apologies for what's probably a non-helpful answer but if one has more reach and the other more digging force I'm thinking the hydraulics are the same but the geometry is different.
All things being equal the longer the boom (or dipper), the less force it's able to create... like if you were trying to do curls with a pole extension in your hands, you lose leverage.
   / What's the difference between the bh760/bh860 backhoes? #3
Probably comes out to 76" verses 86" digging depth.
   / What's the difference between the bh760/bh860 backhoes? #4
You've probably seen this but I figured I'd post it just in case. Have you asked the dealer yet?
I've replied back to you three times and for some reason it's not making my post. Hopefully this one comes in....
Anyway, I said earlier that pretty much you made me realize what my problem was. I was just looking at the numbers on the spec sheet and just compassion then as if they were apples to apples without thinking about it further.
For instance it didn't make sense that the 860 had less bucket force than the 760(it's really pretty much the same).
But thinking about it further it makes sense that they must have used stiffer components in order to apply that same force one foot further away than the 760.
It does appear, as you mentioned, that they most likely use the same cylinders which further explains the similarities in the numbers and the difference in components is shown by the weight.
Sometimes you need someone to tell you your being stupid to make you stop and think about things.
Thanks a bunch. I have the 860 on order will be here in a week or two!
   / What's the difference between the bh760/bh860 backhoes? #6
Awesome!
I have the 760 and it does what I need it to do. I LOVE operating the backhoe because there's so much skill involved and you get continuously better for many, many hours. I've probably got around 50 hours on mine and I'm still figuring out cool new movements with it. I like blending 3 functions at once. I can dig out a big oak stump in about one-third the time that it used to take.
I'm aiming to have zero thinking when operating, just like there's zero thinking when you pick up an apple off the counter.
Congratulations!
   / What's the difference between the bh760/bh860 backhoes? #7
I have the 760 and it’s fun to use. In the future, I plan to convert the mechanical thumb into a hydraulic thumb. Found a cylinder for it, just a matter of plumbing it.
What size cylinder?
   / What's the difference between the bh760/bh860 backhoes? #9
The one I bought from surpluscenter.com (no longer available) is a 2 x 12 x 1.125. The ports were conveniently positioned at one end and the whole thing was yellow. I did take a look for an equivalent and the following is the closest one. You'll need spacers to center the cylinder properly. There was a post about it...
http://www.tractorbynet.com/forums/build-yourself/125912-custom-hydraulic-backhoe-thumb.html
The cylinder...
2x12x1.25 DA Hydraulic Cylinder Wolverine WWXT212-S | Double Acting Hydraulic Cylinders | Hydraulic Cylinders | Hydraulics | www.surpluscenter.com
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2021 SMITH CHALLENGER SCM 400 SWEEPER (A51246)
2021 SMITH...
2018 John Deere 8270R MFWD Tractor (A53342)
2018 John Deere...
