what's the difference between a YM 180d and 186d???
   / what's the difference between a YM 180d and 186d??? #1
BC Dave
Van - S Cariboo; BC
Yanmar YM180D
Hi all Yami's
what is the difference between the 180 & 186's???
I own a 1989 180D; and just got a parts manual for a 186D; but see little difference in the parts; are they 100% parts compatable?
the engine model is the same except has a 3HA72"-N" on the end; what doesthe N designation mean?
I beleive the 186'sd are the next generation of the 180's; they may have the shift on the fly transmission; they look similar but newer; I could post 180 specs if needed ...
   / what's the difference between a YM 180d and 186d??? #2
YM186D was about 1980 to 1985, followed by YM187D 1986-90 approximately. YM187 was longer, a little more knee room, and had a better Powershift. It was essentially the same as YM186 with improvements.
Both have Powershift. It's more than shift-on-the-fly, it's about the same as an automobile AT without the torque converter. The gears are constant-mesh. Shove the shift lever, and that sends hydraulic pressure to engage a different gear's clutch.
I could be wrong but I thought YM180 was the manual-transmission version of YM187.
In all cases, the D suffix means 4 wheel drive.
   / what's the difference between a YM 180d and 186d??? #3
As California said, the 180 and 187 are the manual and Powershift versions of the same tractor, respectively. I have a brochure posted here for them. (Thanks to Scotty Dive for providing these.) You can compare them to the 186 series brochure here, shared with me by rScotty.
I think, basically, the 187/180 is the upgrade/follow on to the 186, with a stretched wheelbase to allow better operation of a mid mount mower and things.
Yes the 180 has a totally manual shift 4 x high / low ... tough to shift into 4 high and goes about 20 MPH max speed in 4H. (as an aside ...How is one to properly change gears to 4 high? Almost impossible to start form a standstill in 4 H; I can manage to try to mesh as I go; but get some grinding ...)
International ... good explanation in the brochure's; thanks!
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2017 Ford Transit Connect Cargo Van (A51692)
2017 Ford Transit...
2006 John Deere 317 Skid Steer (A52384)
2006 John Deere...
2003 Ferris IS1000 52in Zero Turn Mower (A51691)
2003 Ferris IS1000...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
2016 Kenworth T880 Tri-Axle Brenner Fuel Tanker Truck (A51692)
2016 Kenworth T880...
