What's the Deal with Spring Steel
   / What's the Deal with Spring Steel #1
jake98
Veteran Member
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
Can you heat that stuff and un-spring it?
I'd like to flaten out a lock washer and make a spacer out of it.
   / What's the Deal with Spring Steel #2
You sure can.;)
The trick is putting the spring back in it!:laughing:
So I'll heat it up, whack it flat, and then braze it I guess?
   / What's the Deal with Spring Steel #4
You get it red hot, and you can kiss the spring good by. ;)
   / What's the Deal with Spring Steel #5
And you can find out that it's spring steel by ruining a drill bit on it first! Then heat it up like Shield Arc said and let it cool down - no more spring! New drill bit will now work... DAMHIKT
   / What's the Deal with Spring Steel #6
sounds like a lot of trouble to make a flatwasher:D
It's more of a spacer for a spindle bolt. f/w too wide and not thick enough. The f/w that came with it is dragging on the grease seal, this ought to keep it away from it.
..but I hear ya..
   / What's the Deal with Spring Steel #8
Too keep most of the spring strength, visegrip the opening flat and heat the other parts of the ring with a propane torch. Shine up the metal a bit first. When it colors dark blue/purple stop heating. Release after cooling. Should be near flat.
larry
   / What's the Deal with Spring Steel #9
what about taking a zipcut to the appropriate size piece of pipe? then you can get exactly the height you want.
Yeah, I thought of that too. It's becoming a moot point because with the spacers in, somethings still dragging on the other side of the bearings now. Chinese crap, nothing like having to re-work brand new stuff.
JOHN DEERE 5075GN LOT IDENTIFIER 115 (A53084)
JOHN DEERE 5075GN...
UNUSED X-STAR 750 GALLON FUEL TANK (A51247)
UNUSED X-STAR 750...
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
MURRAY 22" 2N1 SELF PROPELLED PUSH LAWN MOWER (A51248)
MURRAY 22" 2N1...
1831 (A51247)
1831 (A51247)
