Whats the correct battery for an H1502
   / Whats the correct battery for an H1502 #1
amanda11270
Pennsylvania
Bolens Iseki H1502
My battery is in need of replacement, according to the date on it, its 10 yrs old so im not complaining. However I have only owned the tractor 5 years and the battery in it is smaller than the space for a battery provided. The previous owner stuck these plastic blocks in place to make the battery fit securely. But can one of you guys check your machine, or if you know what is the correct battery size that goes in it, they usually have a number on them I believe. Thanks alot for any help.
   / Whats the correct battery for an H1502 #2
The largest (most CCA) that will physically fit in the battery compartment is always a good choice. I increased the size of my battery when the OEM one wore out, and I have never regretted it for a second.
If cost is a factor, I have had good experience with the store brand batteries where longer warranties are offered at budget prices. Will they last as long as Interstates? No, but the years of use per $ spent is higher than the pricey brands.
   / Whats the correct battery for an H1502 #3
I have used the Lawn tractor battery from Advance auto with no complaints , other than size is smaller than the tray . It starts the tractor fine I used the terminals differently than original . I used the bolt in tightener of terminal to go through the hole in battery, just spread the terminal clamp and tighten terminal , worked just fine. A couple Rubber bungy cords to hold battery in place, works good for me . A lot cheaper than expensive batteries that aren`t actually better at starting for me ,,my opinion . Good luck
   / Whats the correct battery for an H1502 #4
The Battery from Advance was U1R 340 CCA ,which uses terminal polarity in the right position for the Hi502. Summertime was like 35bucks .
I found it, it is a group 51 battery, Napa had it for $95. I thought my starter solenoid was goin bad for the last year, turns out it was my battery, it hits every time now and turns the starter like mad.
   / Whats the correct battery for an H1502 #6
I think mine is a 51f.
   / Whats the correct battery for an H1502 #7
My previous replies to all the others was what my honest opinion was for your question , in regards to proper battery .
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
SKID STEER FORKS (A53843)
SKID STEER FORKS...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
2012 Ford F550 Service Truck (A52377)
2012 Ford F550...
